Problems with DNSSEC, Pi-hole run in docker, no unbound installed
Hi, I'm running Pi-hole via a Docker container. I'm not using unbound, instead I'm upstreaming to Cloduflare. I've tried to enable the "Use DNSSEC" option from the web ui settings page but whenever I turn that on no address can be resolved. Turning that off restores normal behaviour e.g. addresses get correctly resolved and I can surf the internet ok. As my newbie on Pi-hole maybe I misunderstood it and using unbound as a recursive DNS server is a requirement to get DNSSEC to work ok in Pi-hole?
Update#1 - Posting my (very simple) compose.yaml as suggested by deHakkelaar
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    ports:
      - "53:53/tcp"
      - "53:53/udp"
      - "81:80/tcp"
    environment:
      TZ: 'Europe/Rome'
    volumes:
      - './etc-pihole:/etc/pihole'
    restart: unless-stopped
I'd expect DNS resolution to work ok
Resolution for any public address fails with the following error:
validation is ABANDONED
https://tricorder.pi-hole.net/rkvYDzPO/
With DNSSEC, always make sure date/time on the host is not too far off!
Thanks - I think time settings are good, I assume the docker container syncs with the underlying system in which case I can confirm time settings on the underlying system are ok
It could help if you post the Docker compose file or run command in your original posting?
Any clue anyone? Did some further testing but no luck. As soon as I enable DNSSEC it becomes impossible to resolve any public address
