Problems with dnsmasq and interfaces
[Replace this text with what you think should be happening]
hi everyone, i got several problems on my proxy server, on which i installed pi hole 2 days ago. i got 3 NIC with 3 IP ranges (178.1, 1.1 and 2.1), interfaces are enp1s0, enp2s0 and enp3s0.
pi hole worked fine when installed, but listened to main interface only, which is enp2s0. i found the solution with the 99-inferfaces.conf in here, but it didnt work. Interface listening behavior at web interface is on
Listen on all interfaces
99-interfaces.conf:
interface=enp1s0
interface=enp2s0
interface=enp3s0
after that my dnsmasq had problems with line 44 (dhcp-name-match=set:wpad-ignore,wpad). i found some topics with the same problems but no help. my ftl is v4.3.1
when going with
pihole checkout ftl master
i receive a
Error: Unable to get latest release location from GitHub.
i put the ISP DNS server back on but no connection.
so, how do i get dnsmasq back on track with line 44 and support for the other interfaces?
thanks for your help
You should not use dnsmasq. The error you see is caused by the system-wide dnsmasq on your system being to old.
With Pi-hole you should only use pihole-FTL which includes its own fork of dnsmasq.
thanks for your fast help. i checked on an old backup the original dnsmasq.conf, pihole replaced it and killed all my settings with interfaces.
So i have to purge dnsmasq on my proxy and reinstall pihole?
if so, where do i place my ip ranges for all 3 NIC, my permanent ip for several clients and so on?
Just create a new file inside /etc/dnsmasq.d, name it maybe 99-interfaces.conf
great. fork got same syntax as the original conf on permanent ip and other settings?
Yes, you will not see any differences. It is also guaranteed that our fork inside pihole-FTL is always the latest version whereas some distributions still ship versions that are years old.
thanks, i will test it tomorrow. thanks for your help, have a nice day :slight_smile:
i ran a clear installation on a backup. Now i got problem with ftl. service tells me
Loaded: loaded (/etc/init.d/pihole-FTL; generated; vendor preset: enabled)
Active: active (exited) since Sun 2019-06-02 12:54:28 CEST; 1s ago
Process: 1915 ExecStop=/etc/init.d/pihole-FTL stop (code=exited, status=0/SUCCESS)
Process: 1920 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Jun 02 12:54:28 proxyserver systemd[1]: Starting LSB: pihole-FTL daemon...
Jun 02 12:54:28 proxyserver pihole-FTL[1920]: Not running
Jun 02 12:54:28 proxyserver su[1949]: Successful su for pihole by root
Jun 02 12:54:28 proxyserver su[1949]: + ??? root:pihole
Jun 02 12:54:28 proxyserver su[1949]: pam_unix(su:session): session opened for user pihole by (uid=0)
web interface:
DNS service not running FTL offline
Load: 0.3 0.23 0.1
Memory usage: 6.2 %
FTL Information
The FTL service is offline!
sudo service pihole-FTL restart wont solve the problem
directory @var:
***@proxyserver:/var/run/pihole$ ls -lha
insgesamt 0
drwxr-xr-x 2 pihole pihole 40 Jun 2 12:49 .
so where did i scew up?
Check these two for error lines:
tail /var/log/pihole.log
tail /var/log/pihole-FTL.log
[2019-06-04 16:17:22.754 951] Using log file /var/log/pihole-FTL.log
[2019-06-04 16:17:23.193 951] ########## FTL started! ##########
[2019-06-04 16:17:23.193 951] FTL branch: master
[2019-06-04 16:17:23.193 951] FTL version: v4.3.1
[2019-06-04 16:17:23.193 951] FTL commit: b60d63f
[2019-06-04 16:17:23.193 951] FTL date: 2019-05-25 21:37:26 +0200
[2019-06-04 16:17:23.193 951] FTL user: pihole
[2019-06-04 16:17:23.193 951] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-06-04 16:17:23.193 951] SOCKET_LISTENING: only local
[2019-06-04 16:17:23.193 951] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-06-04 16:17:23.193 951] MAXDBDAYS: max age for stored queries is 365 days
[2019-06-04 16:17:23.193 951] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-06-04 16:17:23.193 951] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-06-04 16:17:23.193 951] DBINTERVAL: saving to DB file every minute
[2019-06-04 16:17:23.193 951] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-06-04 16:17:23.193 951] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-06-04 16:17:23.193 951] PRIVACYLEVEL: Set to 0
[2019-06-04 16:17:23.194 951] IGNORE_LOCALHOST: Show queries from localhost
[2019-06-04 16:17:23.194 951] BLOCKINGMODE: Null IPs for blocked domains
[2019-06-04 16:17:23.194 951] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-06-04 16:17:23.194 951] DBIMPORT: Importing history from database
[2019-06-04 16:17:23.194 951] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-06-04 16:17:23.194 951] PORTFILE: Using /var/run/pihole-FTL.port
[2019-06-04 16:17:23.194 951] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-06-04 16:17:23.194 951] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-06-04 16:17:23.194 951] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-06-04 16:17:23.194 951] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-06-04 16:17:23.194 951] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-06-04 16:17:23.194 951] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-06-04 16:17:23.194 951] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-06-04 16:17:23.194 951] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-06-04 16:17:23.194 951] PARSE_ARP_CACHE: Active
[2019-06-04 16:17:23.195 951] Finished config file parsing
[2019-06-04 16:17:23.404 951] Database version is 3
[2019-06-04 16:17:23.405 951] Database successfully initialized
[2019-06-04 16:17:23.405 951] Imported 0 queries from the long-term database
[2019-06-04 16:17:23.406 951] -> Total DNS queries: 0
[2019-06-04 16:17:23.406 951] -> Cached DNS queries: 0
[2019-06-04 16:17:23.406 951] -> Forwarded DNS queries: 0
[2019-06-04 16:17:23.406 951] -> Exactly blocked DNS queries: 0
[2019-06-04 16:17:23.406 951] -> Unknown DNS queries: 0
[2019-06-04 16:17:23.406 951] -> Unique domains: 0
[2019-06-04 16:17:23.406 951] -> Unique clients: 0
[2019-06-04 16:17:23.406 951] -> Known forward destinations: 0
[2019-06-04 16:17:23.406 951] Successfully accessed setupVars.conf
Error on pihole.log.1, but this shouldnt concern DNS:
Jun 2 16:32:58 dnsmasq[8845]: failed to load names from /etc/pihole/black.list: No such file or directory
Jun 2 16:31:56 dnsmasq[8845]: started, version pi-hole-2.80 cachesize 10000
Jun 2 16:31:56 dnsmasq[8845]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Jun 2 16:31:56 dnsmasq-dhcp[8845]: DHCP, IP range 192.168.2.150 -- 192.168.2.175, lease time 3d
Jun 2 16:31:56 dnsmasq-dhcp[8845]: DHCP, IP range 192.168.1.150 -- 192.168.1.175, lease time 3d
Jun 2 16:31:56 dnsmasq[8845]: using nameserver 1.0.0.1#53
Jun 2 16:31:56 dnsmasq[8845]: using nameserver 1.1.1.1#53
Jun 2 16:31:56 dnsmasq[8845]: read /etc/hosts - 11 addresses
Jun 2 16:31:56 dnsmasq[8845]: read /etc/pihole/local.list - 2 addresses
Jun 2 16:31:56 dnsmasq[8845]: failed to load names from /etc/pihole/black.list: No such file or directory
Jun 2 16:31:57 dnsmasq[8845]: read /etc/pihole/gravity.list - 113443 addresses
Jun 2 16:32:58 dnsmasq[8845]: read /etc/hosts - 11 addresses
Jun 2 16:32:58 dnsmasq[8845]: read /etc/pihole/local.list - 2 addresses
Jun 2 16:32:58 dnsmasq[8845]: read /etc/pihole/gravity.list - 113443 addresses
Jun 2 16:32:59 dnsmasq[8845]: read /etc/pihole/gravity.list - 113443 addresses
Jun 2 16:33:05 dnsmasq[8845]: query[MX] smtp.XXX.de from 127.0.0.1
Jun 2 16:33:05 dnsmasq[8845]: forwarded smtp.XXX.de to 1.0.0.1
Jun 2 16:33:05 dnsmasq[8845]: forwarded smtp.XXX.de to 1.1.1.1
Jun 2 16:33:05 dnsmasq[8845]: query[A] smtp.XXX.de from 127.0.0.1
Jun 2 16:33:05 dnsmasq[8845]: reply smtp.XXX.de is XXX
Jun 2 16:33:05 dnsmasq[8845]: query[AAAA] smtp.XXX.de from 127.0.0.1
Jun 2 16:33:05 dnsmasq[8845]: forwarded smtp.XXX to 1.0.0.1
Jun 2 16:34:02 dnsmasq[8845]: exiting on receipt of SIGTERM
pihole.log is clear
got it, google is your friend:
Seems to be solved by sudo touch /var/lib/misc/dnsmasq.leases sudo chown pihole:pihole /var/lib/misc/dnsmasq.leases sudo reboot
