I do not understand the behavior of nslookup on pihole.
I've to access the devices on my home network with their IPv6
addresses with a newly set Prefix "a:b:c:d::" every day. A
raspberrypi running pihole is one of them. It can be
reached by an IPv6 of the kind "a:b:c:d:1:2:3:4". The ::1:2:3:4
part is constant. I'm using a dynDNS service which I update whenever
the IPv6-prefix is changing. To do so I set an AAAA Record on the
dynDNS server of my provider using a http-gui.
Here is my problem:
dig -t a rpi.mydomain.net @8.8.8.8 gives the correct answer:
; <<>> DiG 9.18.19-1~deb12u1-Debian <<>> -t a rpi.mydomain.net @8.8.8.8
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 45178
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;rpi.mydomain.net. IN A
;; AUTHORITY SECTION:
mydomain.net. 150 IN SOA some bla bla
;; Query time: 15 msec
;; SERVER: 8.8.8.8#53(8.8.8.8) (UDP)
;; WHEN: Tue Jan 09 14:52:18 GMT 2024
;; MSG SIZE rcvd: 117
dig -t aaaa rpi.mydomain.net @8.8.8.8 works also fine:
; <<>> DiG 9.18.19-1~deb12u1-Debian <<>> -t aaaa rpi.mydomain.net @8.8.8.8
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 46276
;rpi.mydomain.net. IN AAAA
rpi.mydomain.net. 60 IN AAAA a:b:c:d:1:2:3:4
;; Query time: 43 msec
;; WHEN: Tue Jan 09 14:52:26 GMT 2024
;; MSG SIZE rcvd: 73
nslookup rpi.mydomain.net gives:
Server: 192.168.178.1
Address: 192.168.178.1#53
Non-authoritative answer:
*** Can't find rpi.mydomain.net: No answer
While pihole.log contains the following information:
Jan 9 15:02:32 dnsmasq[37759]: query[A] rpi.mydomain.net from 192.168.178.1
Jan 9 15:02:32 dnsmasq[37759]: forwarded rpi.mydomain.net to 8.8.8.8
Jan 9 15:02:32 dnsmasq[37759]: reply rpi.mydomain.net is NODATA-IPv4
Jan 9 15:04:41 dnsmasq[37759]: query[AAAA] rpi.mydomain.net from 192.168.178.1
Jan 9 15:04:41 dnsmasq[37759]: forwarded rpi.mydomain.net to 8.8.8.8
Jan 9 15:04:41 dnsmasq[37759]: reply rpi.mydomain.net is a:b:c:d:1:2:3:4
outside of my home environmet I get the proper responds:
Server: 127.0.0.53
Address: 127.0.0.53#53
Address: a:b:c:d:1:2:3:4
The command "ssh nas.mydomain.net" exits with
ssh: Could not resolve hostname nas.mydomain.net: No address associated with hostname
but adds two lines to pihole.log:
dnsmasq[37759]: reply nas.mydomain.net is NODATA-IPv4
dnsmasq[37759]: reply nas.mydomain.net is a:b:c:d:5:6:7:8
BTW, "ssh me@a:b:c:d:5:6:7:8" works just fine.
Any idea what's wrong with my setup?
