I am running PiHole on Windows 10 (i am useing docker),
and I want to use pihole as DHCP server (i cant change dns on my router)
so when I turn off the DHCP server on the router and i turn it on in the panel (pihole),
after that no one can connect to the wifi because they can't get an IP and the network on the pc stoped working
You may want to chose another method to run Pi-hole if you don't have any prior experience with docker. You'll need to know how to set ports, share the network interfaces and handle shared filesystems.
I see, but I already setup everything and its seems to works fine just the DHCP giving me some hardtime even if I don't know much about docker I can still learn
+i dont know any other method
