. i have a problem in setting pi hole + wireguard. im using windows laptop for and dietpi in virtualbox as a pi hole + wireguard server. the only problem is setting the wireguard, the endport should be for server ip public/ddns right?
i could connect my devices outside my homenetwork
- after i set ddns in my router, i cant access router dashboard anymore
- if i set my pi hole address for endpoint, i can browse just fine but i cant access my homenetwork from outside, but if i use ddns/public ip address for endpoint i cant even browse anything
- in my windows if i activate vpn, then the endpoint becomes my pihole dns, but in my iphone the endpoint becomes the public ip
Server conf
[Interface]
Address = 10.6.0.1/24 (tried 10.200.200.0/24)
ListenPort = 443 (tried 51820 too)
PrivateKey = Server_private.key
PostUp = iptables -A FORWARD -i %i -j ACCEPT ; iptables -A FORWARD -o %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
PostDown = iptables -D FORWARD -i %i -j ACCEPT; iptables -D FORWARD -o %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
[Peer]
PublicKey = clientkey
AllowedIPs = 10.6.0.2/32
[Peer]
AllowedIPs = 10.6.0.3/32
[Peer]
AllowedIPs = 10.6.0.4/32
Client Conf
[Interface]
PrivateKey =clientkey
ListenPort = 443 (tried 51820)
Address = 10.6.0.2/24 (tried 10.200.200.0/24)
DNS = 192.168.0.xxx (pihole dns)
[Peer]
PublicKey = serverkey
AllowedIPs = 0.0.0.0/0
Endpoint = my.ddns.net:443 (tried with public ip)
ip tables
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
ACCEPT udp -- anywhere anywhere udp dpt:51820 ctstate NEW
ACCEPT tcp -- 10.200.200.0/24 anywhere tcp dpt:domain ctstate NEW
ACCEPT udp -- 10.200.200.0/24 anywhere udp dpt:domain ctstate NEW
Chain FORWARD (policy DROP)
DOCKER-USER all -- anywhere anywhere
DOCKER-ISOLATION-STAGE-1 all -- anywhere anywhere
DOCKER all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate NEW
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (1 references)
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
is it because my port is closed by the isp?
Port 21 ftp Closed
Port 22 ssh Closed
Port 23 telnet Closed
Port 25 smtp Closed
Port 80 http Closed
Port 110 pop3 Closed
Port 115 sftp Closed
Port 143 imap Closed
Port 443 https Closed
Port 1433 ms-sql-s Closed
Port 3306 mysql Closed
Port 3389 ms-wbt-server Closed
Port 5900 rfb Closed
Port 8080 webcache Closed
