Problem with regex?
Pi-hole Version v4.3.2 Web Interface Version v4.3.2 FTL Version v4.3.1
using the regex list from @mmotti, which contains
^track(ers?|ing)?[0-9]*[-.]
however, in the pihole log, I find tracker.coppersurfer.tk (forwarded to unbound)
Jan  8 09:42:52 dnsmasq[23277]: query[TXT] tracker.coppersurfer.tk from 192.168.2.227
Jan  8 09:42:52 dnsmasq[23277]: forwarded tracker.coppersurfer.tk to 127.10.10.2
Jan  8 09:42:52 dnsmasq[23277]: forwarded tracker.coppersurfer.tk to fdaa:bbcc:ddee:2::5552
Jan  8 09:42:56 dnsmasq[23277]: query[TXT] tracker.coppersurfer.tk from 192.168.2.227
Jan  8 09:42:56 dnsmasq[23277]: forwarded tracker.coppersurfer.tk to 127.10.10.2
Jan  8 09:42:56 dnsmasq[23277]: forwarded tracker.coppersurfer.tk to fdaa:bbcc:ddee:2::5552
and in the unbound log, I find
Jan 08 09:42:49 unbound[5655:2] info: resolving tracker.coppersurfer.tk. TXT IN
because I also use SURICATA on my firewall (pfsense), unbound never gets a response (which is what I want)
but the question remains, why was it forwarded by pihole in the first place?, the manual says:
^abc
matches any domain starting (^) in "abc" like abcdomain.com, abc.domain.com but not def.abc.com
Does this have something to do with query[TXT]?
edit
when I simply dig the domain, I get the expected result (0.0.0.0)
dig tracker.coppersurfer.tk
; <<>> DiG 9.11.5-P4-5.1-Raspbian <<>> tracker.coppersurfer.tk
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 42590
;tracker.coppersurfer.tk.       IN      A
tracker.coppersurfer.tk. 2      IN      A       0.0.0.0
;; Query time: 0 msec
;; WHEN: Thu Jan 09 11:12:31 CET 2020
;; MSG SIZE  rcvd: 68
/edit
Thank you for your time and effort.
Yes. Pi-Hole only blocks A and AAAA queries.
@anon55913113, @DL6ER
In the cname topic, @anon55913113 presented a script to create dummy zone files to block resolving, using unbound.
  • Would this technique be useful to block the TXT queries?
  • What would be the unbound files, configuration, needed to effectively block tracker.coppersurfer.tk?
  • Alternatively, would it be possible to block the domain, using a dnsmasq txt-record (see man page)? How would such a dummy txt-record look like?
Thanks for your time and effort.
The current development version already blocks all types of requests so you won't need to do anything in addition.
FTL v4.x blocks only A and AAAA as mentioned by @jfb.
