Problem with own blacklist: Unable to parse results from queryads.php
Hello,
Environment
Pi-hole inside a docker container on my Synology NAS.
Pi-hole version: 3.3.1
Web interface version: 3.3
FTP version: 3.0
Pi-hole should load a local blacklist and block the domains
Pi-hole is loading the blacklist but displays an error message
Debug token:
mgqwx41zw6
Details
I would like to extend the blocked domains with a list I've created.
For simplicity there is only one example domain which should be blocked.
Content of default.list
x1.com
Regarding the docs I can extend the adlists.list file and append my files:
##Custom files
file:///etc/blacklists/default.list
The list is being loaded:
[i] Target: local (default.list)
Now when I try to open the blocked domain I get an error:
[ERROR]: Unable to parse results from queryads.php: Unhandled error message (7 (no associated adlists URL found))
The log
Jul  3 13:04:05 dnsmasq[439]: 50 127.0.0.1/35023 query[A] diginc-pi-hole1 from 127.0.0.1
Jul  3 13:04:05 dnsmasq[439]: 50 127.0.0.1/35023 /etc/pihole/local.list diginc-pi-hole1 is 192.168.0.5
Jul  3 13:04:05 dnsmasq[439]: 51 127.0.0.1/35023 query[AAAA] diginc-pi-hole1 from 127.0.0.1
My second try was to put the file on a server and let Pi-hole download the list:
##Custom files
http://192.168.0.2/blacklists/default.list
Result: Works perfectly.
Can someone help me please if this is a bug?
Thanks in advance and best regards
Is the /etc/blacklists/default.list inside the container, or is the file outside and mapped in via a volume?
I've mapped the whole blacklists folder inside the container.
/docker/pihole/data/blacklists --> /etc/blacklists
root@diginc-pi-hole1:/# ls -la /etc/blacklists/
total 4
drwxr-xr-x 1 1024 users   24 Jul  3 13:45 .
drwxr-xr-x 1 root root  2154 Jul  2 08:49 ..
-rwxr-xr-x 1 1024 users   10 Jul  2 09:25 default.list
@Mcat12 Does that error message mean anything for you?
Just in case if it's important:
On Github there was an similar issue created (Block page not displaying, instead i get some error message from pihole · Issue #2023 · pi-hole/pi-hole · GitHub)
However this was closed with the comment
Ok I think I resolved this, it seems I had a block list specified that was not in the right format. It was messing pihole up quite a bit. Once I removed it, it seems to work ok again.
But if this would here be the case, then loading my list from a server should produce the same error as loading from a local folder. But this is not the case.
What is the output of pihole -q x1.com
Here we go
root@diginc-pi-hole1:/# pihole -q x1.com
 Match found in list.0.raw.githubusercontent.com.domains:
   t.mdn2015x1.com
   c.flx1.com
   0azx1.com
 Match found in list.1.mirror1.malwaredomains.com.domains:
   netflixuser-support.validate-user.activation.safeguard.key.1uh3.verify-netflix1.com
   verify-netflix1.com
 Match found in list.2.sysctl.org.domains:
   c.flx1.com
   p.pxl2015x1.com
 Match found in list.6.hosts-file.net.domains:
   p.pxl2015x1.com
   t.mdn2015x1.com
   www.adx1.com
 Match found in list.7.local.domains:
   www.x1.com
What is the output of these commands?
pihole -q x1.com -bp
curl http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=x1.com&bp
root@diginc-pi-hole1:/# pihole -q x1.com -bp
  [i] No exact results found for x1.com found within block lists
and
root@diginc-pi-hole1:/# curl "http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=x1.com&bp"
data:   [i] No exact results found for x1.com found within block lists
data:
data:
I've put the url in double quotes. Without double quotes the output is different:
root@diginc-pi-hole1:/# curl http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=x1.com&bp
[1] 7379
bash: bp: command not found
root@diginc-pi-hole1:/# data:  Match found in list.0.raw.githubusercontent.com.domains:
data:
data:    t.mdn2015x1.com
data:
data:    c.flx1.com
data:
data:    0azx1.com
data:
data:  Match found in list.1.mirror1.malwaredomains.com.domains:
data:
data:    netflixuser-support.validate-user.activation.safeguard.key.1uh3.verify-netflix1.com
data:
data:    verify-netflix1.com
data:
data:  Match found in list.2.sysctl.org.domains:
data:
data:    c.flx1.com
data:
data:    p.pxl2015x1.com
data:
data:  Match found in list.6.hosts-file.net.domains:
data:
data:
data:
data:    www.adx1.com
data:
data:  Match found in list.7.local.domains:
data:
data:    www.x1.com
data:
data:
Are you accessing the block page over IPv6? There are currently some issues with that.
No, I'm just using IPv4. IPv6 is deactivated on my machine.
My ISP is giving me an IPv4 too.
Edit:
I've investigated the problem further.
Adding example.com to my blacklist works perfectly (local file / remote file).
So there seems to be a bug (?) which causes pihole to produce this error only for certain domains - like x1.com
