i get this error on ubuntu 16.04 running in chroot on my chromebook
What URL are you using to access the web interface? Can you take a screenshot of the XHR section of the Networking tab in the dev tools after you reload the page?
What is the output of curl -i http://192.168.1.131/admin/api.php?summary
(xenial)critic@localhost:~$ curl -i http://192.168.1.131/admin/api.php?summary?
HTTP/1.1 200 OK
X-Pi-hole: The Pi-hole Web interface is working!
X-Frame-Options: DENY
Set-Cookie: PHPSESSID=pjr2efph8n68phktgsto030n67; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Content-type: application/json
Transfer-Encoding: chunked
Date: Fri, 31 Mar 2017 23:14:57 GMT
Server: lighttpd/1.4.35
Was there output like this at the bottom?
{"domains_being_blocked":"103,013","dns_queries_today":"7,575","ads_blocked_today":"962","ads_percentage_today":"12.7"}
nope only what i copy
Run pihole -d
for a debug token.
Your debug token is : 36zmw4osto
Try the command again, then check /var/log/lighttpd/error.log
for any errors.
2017-04-02 07:36:02: (server.c.1242) logfiles cycled UID = 0 PID = 30245
Have you tried repairing Pi-hole via pihole -r
? If that doesn't help, try reinstalling.
i will try to repair and/or reinstall later on today
should i worry about the error msg from lighttpd?
That message isn't really an error, just a notice that the log file was rotated at some point.
add pihole ip to my adblocker whitelist fix this problem
