The issue I am facing:
While running the command "pihole -up" I was hoping this would upgrade me to the current version. The update failed, a few obviously notable items include:
-[i] SELinux not detected
-[✗] Unsupported OS detected: Raspbian 9
-Unable to complete update, please contact Pi-hole Support
-Update attempt did something, I now see the "Local DNS" tab which was not present before. But not all tabs are without error...
Details about my system:
Raspberry Pi Zero.
FTL v 4.3.1
Updated Gravity a few times
And, after years of not updating, I just ran the update mentioned above via SSH.
Teleporter backup not working, any chance that my setting were being backed up somewhere automatically. I'm concerned that pihole -up failure is related to this inability to backup. Clicking the button does not seem to do anything.
I just ran:
sudo PIHOLE_SKIP_OS_CHECK=true pihole -r
Now FTL was updated!
Pi-hole v5.11.4 FTL v5.16.1 Web Interface v5.13
Also, I was able to save a backup file.
I suppose now I need to update Debian 9 to something newer, moving one OS at a time. If that fails start from scratch and import the settings via Teleporter. Yes?
I would advise not doing this. Your probability of success is low.
Skip the in-place upgrade and just flash a fresh Debian 11 image. Then restore your Pi-hole settings from the teleporter export. Note - don't save the teleporter file on your Pi SD card - put it somewhere else.
Hi JFB, I have various 32GB cards that were probably used in an audio recorder or a GOPro.... I suppose you are going to suggest bran spanking new media?
Also, my current pi model hardware is a model w. I see there is a new version W (v2) that is 5X faster, do I want the new pi for this application? Will I see a difference?
A Zero W is also more than powerful enough to run Pi-hole. I have three of them, and a Zero 2 W. There is no difference in Pi-hole performance between any of them.
