Problem setting up Openvpn, and resolving to the server
Hi everyone,
I am a linux n00b but I want to use Pihole in combination with OpenVPN to add VPN functionality to my home network, I have done the following:
Using the Pi Hole+ 4.0 documentation in this order:
  • Pi-hole and OpenVPN Server
  • Installation
  • Installed PiHole
  • Firewall Configuration
  • Optional: Dual operation: LAN & VPN at the same time
  • Configuring DNS-Over-HTTPS on Pi-hole
Problem is I presume OpenVPN is listening on 10.8.0.1 but I cant set my router to forward the port to that IP address as its out of range?
A way to forward 10.0.0.5:194 to 10.8.0.1:194
I have no idea what I am doing.
This process collects information from your Pi-hole, and optionally uploads it t                                                      o a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations                                                      .  This is accomplished by running tests against our software and providing the                                                       user with links to FAQ articles when a problem is detected.  Since we are a smal                                                      l team and Pi-hole has been growing steadily, it is our hope that this will help                                                       us spend more time on development.
NOTE: All log files auto-delete after 48 hours and ONLY the Pi-hole developers c                                                      an access your data via the given token. We have taken these extra steps to secu                                                      re your data and will work to further reduce any personal information gathered.
*** [ INITIALIZING ]
[i] 2018-08-04:13:35:38 debug log has been initialized.
[i] Core: v3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: FTLDNS (https://discourse.pi-hole.net/t/the-pihole-command-with-exam                                                      ples/738#checkout)
[i] Commit: v3.3-414-g169a428
[i] Web: v3.2.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Commit: v3.2.1-303-g8c7521f3
[āœ“] FTL: vDev-3e40158 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/2                                                      49)
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.76
[i] 1.4.45
[i] 7.0.30
[āœ“] Debian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[āœ“] armv7l
[āœ“] IPv4 address(es) bound to the eth0 interface:
   10.0.0.5/24 matches the IP found in /etc/pihole/setupVars.conf
[āœ“] IPv6 address(es) bound to the eth0 interface:
   fe80::42:eeff:fef1:f313 does not match the IP found in /etc/pihole/setupVars.                                                      conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   As long as one of them is green, and it matches what is in /etc/pihole/setupV                                                      ars.conf, there is no need for concern.
   The link to the FAQ is for an issue that sometimes occurs when the IPv6 addre                                                      ss changes, which is why we check for it.
[i] Default IPv4 gateway: 10.0.0.86
   * Pinging 10.0.0.86...
[āœ“] Gateway responded.
*:22 sshd (IPv4)
*:22 sshd (IPv6)
127.0.0.1:5353 unbound (IPv4)
127.0.0.1:8953 unbound (IPv4)
*:53 pihole-FTL (IPv4)
*:53 pihole-FTL (IPv6)
127.0.0.1:4711 pihole-FTL (IPv4)
[::1]:4711 pihole-FTL (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
*** [ DIAGNOSING ]: Name resolution (IPv4) using a random blocked domain and a k                                                      nown ad-serving domain
[āœ“] view.atdmt.com.77622.9661.302br.net is 0.0.0.0 via localhost (127.0.0.1)
[āœ“] view.atdmt.com.77622.9661.302br.net is 0.0.0.0 via Pi-hole (10.0.0.5)
[āœ“] doubleclick.com is 216.58.223.46 via a remote, public DNS server (8.8.8.8)
[āœ—] dnsmasq daemon is inactive
[āœ“] lighttpd daemon is active
[āœ“] pihole-FTL daemon is active
    PIHOLE_INTERFACE=eth0
    IPV4_ADDRESS=10.0.0.5/24
    IPV6_ADDRESS=
    QUERY_LOGGING=true
    INSTALL_WEB_SERVER=true
    INSTALL_WEB_INTERFACE=true
    LIGHTTPD_ENABLED=true
    DNSMASQ_LISTENING=all
    PIHOLE_DNS_1=127.0.0.1#5353
    DNS_FQDN_REQUIRED=false
    DNS_BOGUS_PRIV=false
    DNSSEC=false
    CONDITIONAL_FORWARDING=false
[āœ“] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[āœ“] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 3039333 Aug  4 12:44 /etc/pihole/gravity.list
   0.0.0.0
   0.r.msn.com
   0.start.bz
   000.0x1f4b0.com
   zzz.clickbank.net
   zzzezeroe.fr
   zzzpooeaz-france.com
   zzzrtrcm2.com
-rw-r--r-- 1 root root 633 Aug  4 12:23 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 39 Aug  4 12:44 /etc/pihole/local.list
   10.0.0.5 orangepizero
   10.0.0.5 pi.hole
-rw-r--r-- 1 root root 234 Aug  4 12:43 /etc/pihole/logrotate
   /var/log/pihole.log {
        su root root
        daily
        copytruncate
        rotate 5
        compress
        delaycompress
        notifempty
        nomail
   /var/log/pihole-FTL.log {
        su root root
        weekly
        copytruncate
        rotate 3
        compress
        delaycompress
        notifempty
        nomail
-rw-r--r-- 1 root root 1514 Aug  4 12:50 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   cache-size=10000
   log-queries=extra
   local-ttl=2
   log-async
   server=127.0.0.1
   except-interface=nonexisting
-rw-r--r-- 1 root root 3027 Aug  4 12:43 /etc/lighttpd/lighttpd.conf
   server.modules = (
        "mod_access",
        "mod_accesslog",
        "mod_auth",
        "mod_expire",
        "mod_compress",
        "mod_redirect",
        "mod_setenv",
        "mod_rewrite"
   server.error-handler-404    = "pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   index-file.names            = ( "index.php", "index.html", "index.lighttpd.ht                                                      ml" )
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/h                                                      tml", "text/plain" )
   include_shell "/usr/share/lighttpd/create-mime.assign.pl"
   include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'let                                                      sencrypt.conf' -printf 'include \"%p\"
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
           "X-Frame-Options" => "DENY"
       $HTTP["url"] =~ ".ttf$" {
        url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Aug  4 12:43 /etc/cron.d/pihole
   32 4   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker loc                                                      al
   46 16  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remo                                                      te
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote rebo                                                      ot
-rw-r--r-- 1 www-data www-data 533 Aug  4 12:59 /var/log/lighttpd/error.log
   2018-08-04 12:21:27: (log.c.217) server started
   2018-08-04 12:22:55: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-08-04 12:22:56: (log.c.217) server started
   2018-08-04 12:38:43: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-08-04 12:39:12: (log.c.217) server started
   2018-08-04 12:44:06: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-08-04 12:44:07: (log.c.217) server started
   2018-08-04 12:59:31: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-08-04 12:59:46: (log.c.217) server started
-rw-r--r-- 1 pihole pihole 19542 Aug  4 12:59 /var/log/pihole-FTL.log
   [2018-08-04 12:23:00.215] ########## FTL started! ##########
   [2018-08-04 12:23:00.215] FTL branch: v3.0
   [2018-08-04 12:23:00.215] FTL version: v3.0
   [2018-08-04 12:23:00.215] FTL commit: a1b2fa03f8f3e3713b57a26a4e9a062fec0573d                                                      7
   [2018-08-04 12:23:00.215] FTL date: 2018-02-14 12:45:47 -0800
   [2018-08-04 12:23:00.216] FTL user: pihole
   [2018-08-04 12:23:00.216] Notice: Found no readable FTL config file
   [2018-08-04 12:23:00.216]         Using default settings
   [2018-08-04 12:23:00.216] Starting config file parsing (/etc/pihole/pihole-FT                                                      L.conf)
   [2018-08-04 12:23:00.216]    SOCKET_LISTENING: only local
   [2018-08-04 12:23:00.216]    QUERY_DISPLAY: Show queries
   [2018-08-04 12:23:00.216]    AAAA_QUERY_ANALYSIS: Show AAAA queries
   [2018-08-04 12:23:00.216]    MAXDBDAYS: max age for stored queries is 365 day                                                      s
   [2018-08-04 12:23:00.216]    RESOLVE_IPV6: Resolve IPv6 addresses
   [2018-08-04 12:23:00.216]    RESOLVE_IPV4: Resolve IPv4 addresses
   [2018-08-04 12:23:00.216]    DBINTERVAL: saving to DB file every minute
   [2018-08-04 12:23:00.216]    DBFILE: Using /etc/pihole/pihole-FTL.db
   [2018-08-04 12:23:00.216]    MAXLOGAGE: Importing up to 24.0 hours of log dat                                                      a
   [2018-08-04 12:23:00.216] Finished config file parsing
   [2018-08-04 12:23:00.222] Found no other running pihole-FTL process
   [2018-08-04 12:23:00.224] PID of FTL process: 22591
   [2018-08-04 12:23:00.225] Error: failed to read /etc/pihole/list.preEventHori                                                      zon
   [2018-08-04 12:23:00.225] Gravity list entries: -1
   [2018-08-04 12:23:00.225] No blacklist present
   [2018-08-04 12:23:00.225] No wildcard blocking list present
   [2018-08-04 12:23:00.226] db_init() - Cannot open database (14): unable to op                                                      en database file
   [2018-08-04 12:23:00.226] Creating new (empty) database
   [2018-08-04 12:23:00.428] Database initialized
   [2018-08-04 12:23:00.429] Imported 0 queries from the long-term database
   [2018-08-04 12:23:00.430] Starting initial log file parsing
   [2018-08-04 12:23:00.430] Reading from /var/log/pihole.log (rw-r--r--)
   [2018-08-04 12:23:00.430] Finished initial log file parsing
   [2018-08-04 12:23:00.431]  -> Total DNS queries: 0
   [2018-08-04 12:23:00.431]  -> Cached DNS queries: 0
   [2018-08-04 12:23:00.431]  -> Forwarded DNS queries: 0
   [2018-08-04 12:59:45.413]    MAXLOGAGE: Importing up to 24.0 hours of log dat                                                      a
   [2018-08-04 12:59:45.413]    PRIVACYLEVEL: Set to 0
   [2018-08-04 12:59:45.413]    IGNORE_LOCALHOST: Show queries from localhost
   [2018-08-04 12:59:45.413]    BLOCKINGMODE: Null IPs for blocked domains
   [2018-08-04 12:59:45.413]    REGEX_DEBUGMODE: Inactive
   [2018-08-04 12:59:45.413] Finished config file parsing
   [2018-08-04 12:59:45.413] INFO: No whitelist file found
   [2018-08-04 12:59:45.413] Compiled 0 Regex filters and -1 whitelisted domains                                                       in 0.3 msec (0 errors)
   [2018-08-04 12:59:45.692] Database successfully initialized
   [2018-08-04 12:59:45.711] Notice: Increasing queries struct size from 0 to 10                                                      000
   [2018-08-04 12:59:45.712] Notice: Increasing domains struct size from 0 to 10                                                      00
   [2018-08-04 12:59:45.712] Notice: Increasing clients struct size from 0 to 10
   [2018-08-04 12:59:45.712] New forward server: 8.8.4.4 (0/0)
   [2018-08-04 12:59:45.712] Notice: Increasing forwarded struct size from 0 to                                                       4
   [2018-08-04 12:59:45.712] Notice: Increasing overTime struct size from 0 to 1                                                      00
   [2018-08-04 12:59:45.712] New forward server: 8.8.8.8 (1/4)
   [2018-08-04 12:59:45.713] New forward server: 127.0.0.1 (2/4)
   [2018-08-04 12:59:45.715] Imported 366 queries from the long-term database
   [2018-08-04 12:59:45.715]  -> Total DNS queries: 366
   [2018-08-04 12:59:45.715]  -> Cached DNS queries: 100
   [2018-08-04 12:59:45.715]  -> Forwarded DNS queries: 229
   [2018-08-04 12:59:45.715]  -> Exactly blocked DNS queries: 37
   [2018-08-04 12:59:45.715]  -> Unknown DNS queries: 0
   [2018-08-04 12:59:45.715]  -> Unique domains: 118
   [2018-08-04 12:59:45.715]  -> Unique clients: 2
   [2018-08-04 12:59:45.715]  -> Known forward destinations: 3
   [2018-08-04 12:59:45.715] Successfully accessed setupVars.conf
   [2018-08-04 12:59:45.843] PID of FTL process: 968
   [2018-08-04 12:59:45.843] Listening on port 4711 for incoming IPv4 telnet con                                                      nections
   [2018-08-04 12:59:45.844] Listening on port 4711 for incoming IPv6 telnet con                                                      nections
   [2018-08-04 12:59:45.844] Listening on Unix socket
   [2018-08-04 12:59:45.846] FATAL: Trying to free NULL pointer in free_whitelis                                                      t_domains() (regex.c:73)
   [2018-08-04 12:59:45.846] INFO: No whitelist file found
   [2018-08-04 12:59:45.846] Compiled 0 Regex filters and -1 whitelisted domains                                                       in 0.1 msec (0 errors)
   [2018-08-04 12:59:47.323] /etc/pihole/gravity.list: parsed 133608 domains (to                                                      ok 1427.4 ms)
*** [ DIAGNOSING ]: Locale
    LANG=en_US.UTF-8
-rw-r--r-- 1 pihole pihole 335940 Aug  4 13:36 /var/log/pihole.log
   -----head of pihole.log------
   Aug  4 12:22:53 dnsmasq[22394]: started, version 2.76 cachesize 10000
   Aug  4 12:22:53 dnsmasq[22394]: compile time options: IPv6 GNU-getopt DBus i1                                                      8n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
   Aug  4 12:22:53 dnsmasq[22394]: warning: ignoring resolv-file flag because no                                                      -resolv is set
   Aug  4 12:22:53 dnsmasq[22394]: using nameserver 8.8.4.4#53
   Aug  4 12:22:53 dnsmasq[22394]: using nameserver 8.8.8.8#53
   Aug  4 12:22:53 dnsmasq[22394]: read /etc/hosts - 6 addresses
   Aug  4 12:22:53 dnsmasq[22394]: failed to load names from /etc/pihole/local.l                                                      ist: No such file or directory
   Aug  4 12:22:53 dnsmasq[22394]: failed to load names from /etc/pihole/black.l                                                      ist: No such file or directory
   Aug  4 12:22:53 dnsmasq[22394]: failed to load names from /etc/pihole/gravity                                                      .list: No such file or directory
   Aug  4 12:23:03 dnsmasq[22394]: 1 127.0.0.1/51788 query[AAAA] raw.githubuserc                                                      ontent.com from 127.0.0.1
   Aug  4 12:23:03 dnsmasq[22394]: 1 127.0.0.1/51788 forwarded raw.githubusercon                                                      tent.com to 8.8.4.4
   Aug  4 12:23:03 dnsmasq[22394]: 1 127.0.0.1/51788 forwarded raw.githubusercon                                                      tent.com to 8.8.8.8
   Aug  4 12:23:03 dnsmasq[22394]: 1 127.0.0.1/51788 reply raw.githubusercontent                                                      .com is <CNAME>
   Aug  4 12:23:03 dnsmasq[22394]: 1 127.0.0.1/51788 reply github.map.fastly.net                                                       is NODATA-IPv6
   Aug  4 12:23:03 dnsmasq[22394]: 2 127.0.0.1/47617 query[A] raw.githubusercont                                                      ent.com from 127.0.0.1
   Aug  4 12:23:03 dnsmasq[22394]: 2 127.0.0.1/47617 cached raw.githubuserconten                                                      t.com is <CNAME>
   Aug  4 12:23:03 dnsmasq[22394]: 2 127.0.0.1/47617 forwarded raw.githubusercon                                                      tent.com to 8.8.8.8
   Aug  4 12:23:03 dnsmasq[22394]: 3 127.0.0.1/58077 query[PTR] 4.4.8.8.in-addr.                                                      arpa from 127.0.0.1
   Aug  4 12:23:03 dnsmasq[22394]: 3 127.0.0.1/58077 forwarded 4.4.8.8.in-addr.a                                                      rpa to 8.8.8.8
   Aug  4 12:23:03 dnsmasq[22394]: 2 127.0.0.1/47617 reply raw.githubusercontent                                                      .com is <CNAME>
[āœ“] ** FINISHED DEBUGGING! **
    * The debug log can be uploaded to tricorder.pi-hole.net for sharing with de                                                      velopers only.
    * For more information, see: https://pi-hole.net/2016/11/07/crack-our-medica                                                      l-tricorder-win-a-raspberry-pi-3/
    * If available, we'll use openssl to upload the log, otherwise it will fall                                                       back to netcat.
You would need to forward the port to the internal IP (10.0.0.5) of your VPN server.
The device hosting the Pi-hole and the VPN has instructions (set by the installation setup process) to route/mask between the LAN range and VPN range automatically.
You also need to set up Pi-hole to listen to all, under the DNS tab on the /admin/ interface.
We need to instruct Pi-hole to respond to tun0 (virtual interface for the VPN) requests.
That should do it.
Make sure that the port forwarding rule port, matches the one that the clients connect to.
I’d select/configure a higher port though. 194, could conflict with other stuff ...
Thanks I acutally got it sorted, it was stupidest mistake ever, forwarding tcp instead of udp on my router, guess thats what happens when you dont really understand the tutorial (my fault) and thus forget to check the basics first lol
PS Working beautifully now
