sudo service lighttpd status
Redirecting to /bin/systemctl status lighttpd.service
● lighttpd.service - Lightning Fast Webserver With Light System Requirements
Loaded: loaded (/usr/lib/systemd/system/lighttpd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2018-11-02 17:45:07 EDT; 1h 12min ago
Process: 12747 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Main PID: 12747 (code=exited, status=255)
Nov 02 17:45:07 pi-hole systemd[1]: Started Lightning Fast Webserver With Light System Requirements.
Nov 02 17:45:07 pi-hole systemd[1]: Starting Lightning Fast Webserver With Light System Requirements...
Nov 02 17:45:07 pi-hole lighttpd[12747]: 2018-11-02 17:45:07: (configfile.c.1462) commaned "cat external.conf 2>/dev/null" exited non-zero: 1
Nov 02 17:45:07 pi-hole lighttpd[12747]: 2018-11-02 17:45:07: (configfile.c.1277) source: /etc/lighttpd/lighttpd.conf line: 94 pos: 1 parser failed somehow near here: (EOL)
Nov 02 17:45:07 pi-hole systemd[1]: lighttpd.service: main process exited, code=exited, status=255/n/a
Nov 02 17:45:07 pi-hole systemd[1]: Unit lighttpd.service entered failed state.
Nov 02 17:45:07 pi-hole systemd[1]: lighttpd.service failed.
**Outpout of service dnsmasq status -l:**
Redirecting to /bin/systemctl status -l dnsmasq.service
● dnsmasq.service - DNS caching server.
Loaded: loaded (/usr/lib/systemd/system/dnsmasq.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2018-11-03 08:14:56 EDT; 10s ago
Process: 17790 ExecStart=/usr/sbin/dnsmasq -k (code=exited, status=2)
Main PID: 17790 (code=exited, status=2)
Nov 03 08:14:56 pi-hole systemd[1]: Started DNS caching server..
Nov 03 08:14:56 pi-hole systemd[1]: Starting DNS caching server....
Nov 03 08:14:56 pi-hole dnsmasq[17790]: dnsmasq: failed to create listening socket for port 53: Address already in use
Nov 03 08:14:56 pi-hole systemd[1]: dnsmasq.service: main process exited, code=exited, status=2/INVALIDARGUMENT
Nov 03 08:14:56 pi-hole systemd[1]: Unit dnsmasq.service entered failed state.
Nov 03 08:14:56 pi-hole systemd[1]: dnsmasq.service failed.
And yeah, I copy/pasted the outpout so I think there's a little typo
The dnsmasq part was replaced by Pi-hole's own version of the dnsmasq source code so you wont need to run dnsmasq anymore as a separate process/daemon:
Whats output for below one ?
pi@noads:~ $ pihole status
[✓] DNS service is running
