Previously Blocked Domains Now Showing as Allowed...Unsure What Changed
Hey everyone, sorry for the bother here, but I’m running into something odd and could use a sanity check.
For months and months, my Pi-hole dashboard showed a much larger set of blocked domains, including the usual “easy win” Smart TV trackers (Samsung, LG, Roku, etc.) along with Facebook, TikTok, and similar social telemetry domains. Everything worked great, and I could clearly see them being blocked in Query Log and Top Blocked Domains.
Recently, however, these domains have started showing up as green/allowed instead of blocked/not-permitted, and I can’t recall what configuration change might have caused this.
sudo pihole -d
Here you go!
https://tricorder.pi-hole.net/s8BDRyXd/
You only have one group (Default group), but this group is disabled (enabled=0 means diasbled):
*** [ DIAGNOSING ]: Groups
   id    enabled  name                                                date_added           date_modified        description
   0        0     Default                                             2025-02-24 11:59:24  2025-03-11 08:46:06
As a result, all lists are disabled too.
Just re-enable the default group and Pi-hole will start to block domains again.
Thank you! I’ve never used that function before and well, now am reading more about it. Not sure how that changed, but thank you!
