I'm trying to setup powerdns-recursor and pihole in docker containers on the same raspberry pi.
I want my pihole to either block certain traffic, or forward it to powerdns in the other container. I want powerdns to work as a recursive resolver, but if it can't find a DNS record, forward requests to cloudflare resolver at 1.1.1.1. And if pihole is down, just forward requests to cloudflare.
I have the following docker-compose.yml and conf files.
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
environment:
TZ: 'MyCity/MyCountry' # e.g., 'America/New_York'
WEBPASSWORD: '<PASSWORD>' # Set your web interface password
volumes:
- './pihole/resolv.conf:/etc/resolv.conf'
- './pihole/setupVars.conf:/etc/pihole/setupVars.conf'
dns:
- 127.0.0.1
- 1.1.1.1
ports:
- '53:53/tcp'
- '53:53/udp'
- '80:80'
restart: unless-stopped
networks:
- my_custom_network
powerdns:
container_name: powerdns
image: powerdns/pdns-recursor-51
volumes:
- './recursor.conf:/etc/powerdns/recursor.conf'
ports:
- '5354:53/tcp'
- '5354:53/udp'
networks:
- my_custom_network
networks:
my_custom_network:
driver: bridge
The recursor.conf
local-address=0.0.0.0
local-address=[::]
include-dir=/etc/powerdns/recursor.d
forward-zones-recurse=.=1.1.1.1
allow-from=<my network's IP>/24
loglevel=9
And this is my setupVars.conf
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=172.19.0.3
IPV6_ADDRESS=
PIHOLE_DNS_1=powerdns#5354
PIHOLE_DNS_2=1.1.1.1
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
CACHE_SIZE=10000
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSMASQ_LISTENING=local
WEBPASSWORD=<some password>
BLOCKING_ENABLED=true
When I spin up the containers and docker exec into the pihole container the setupVars are completely different, defaulting to 8.8.8.8 as the upstream DNS server. As a result, nothing is hitting the powerdns resolver.
I don't want to have to exec into the container each time to update the values, or use the web admin host, I'd just like to be able to setup a conf file and then spin up the containers. Is this possible?
