I just searched through the code of the installer and found a bug (i think).
The IP check you mentioned is there (valid_ip) but the problem i see is this:
if [[ ${ip} =~ [1]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}$ ]]; then
This checks if the IP has the numbers 0-9 in it which can go up to 3 digits. The problem is that IP's can only go up to 255.255.255.255, this check would let a IP such as 999.999.999.999 count as valid.
You're not wrong, it's mostly for formatting of the numbers, it's rather difficult to actually check for a valid IP (IPv4), very difficult for v6 in hex notation.
# Test an IP address for validity:
# Usage:
# valid_ip IP_ADDRESS
# if [[ $? -eq 0 ]]; then echo good; else echo bad; fi
# OR
# if valid_ip IP_ADDRESS; then echo good; else echo bad; fi
function valid_ip()
local ip=$1
local stat=1
if [[ $ip =~ ^[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}$ ]]; then
OIFS=$IFS
IFS='.'
ip=($ip)
IFS=$OIFS
[[ ${ip[0]} -le 255 && ${ip[1]} -le 255 \
&& ${ip[2]} -le 255 && ${ip[3]} -le 255 ]]
stat=$?
fi
return $stat
We could also try to dig something from the provided IP. If there is no result - well then that IP might be valid in principle, but still unusable?
if [[ $PIHOLE_DNS_1 =~ .*:.* ]]; then
dns1=IPv6
else
dns1=IPv4
fi
if [[ $PIHOLE_DNS_2 =~ .*:.* ]]; then
dns2=IPv6
else
dns2=IPv4
fi
lookupDNS1="$(nslookup -retry=1 -timeout=5 google.de $PIHOLE_DNS_1)"
if [[ $lookupDNS1 == *";; connection timed out; no servers could be reached"* ]]; then
echo "Your first DNS server ($dns1) isn't working!"
else
echo "Your first DNS server ($dns1) is working!"
fi
lookupDNS2="$(nslookup -retry=1 -timeout=5 google.de $PIHOLE_DNS_2)"
if [[ $lookupDNS2 == *";; connection timed out; no servers could be reached"* ]]; then
echo "Your second DNS server ($dns2) isn't working!"
else
echo "Your second DNS server ($dns2) is working!"
fi
This can also be used to see if a IPv6 connection is avaliable.
ipv6test="$(nslookup -retry=1 -timeout=5 google.de 2001:4860:4860::8888)"
if [[ $ipv6test == *";; connection timed out; no servers could be reached"* ]]; then
echo "You don't have a IPv6 connection!"
else
echo "You have a Ipv6 connection!"
fi
Okay, this approach needs some more protection about injection of bad code through the entered variables. What is the advantage of using nslookup? We know that dig is always available.
