Port 4567 Open (Bullguard IoT Scanner)
I am running Pi-hole for both DHCP and DNS. DHCP is switched off on my TP-Link Archer C9 router. Everything seems to work OK, however!
When running Bullguards IoT scanner at http://iotscanner.bullguard.com/, the results show that my network is accessible via the internet on port 4567 and am therefore vulnerable to attacks. If I switch back to my original configuration by removing Pi-hole and switching DHCP back ON on my router, then running Bullguards IoT scanner shows my network to be safe!
Being open to attack is obviously not desirable. Is this a Pi-hole problem or a Router (firewall) problem?
3lvghd2z8b
We don't have any processes running on port 4567. We run DNS on port 53 and lighttpd on port 80.
Do you have VerizonFIOS?
Any forwarded ports, would be on your router, not the Pi-hole.
However, just to rule it out, if you are familiar with iptables, you can create a basic firewall that blocks port 4567.
I don't even know what VerizonFIOS is. I'm in the UK by the way!
I would not be related to Pi-hole, that's just not a port that we access.
What I don't understand is that without Pi-hole there is no problem!
If the scanner is a web-based scanner, then it's probing your router and unless you have a DMZ that you've placed the Raspberry Pi in and are forwarding ports via your router or have the Raspberry Pi exposed to the internet, I don't know why you are getting a hit on that port. We can't access your router to change or open ports.
What are you running Pi-hole on?
I'm assuming a raspberry pi. If so, is it a clean copy of raspbian with nothing else running alongside it?
It's absolutely clean, i.e. Pi-hole is the only thing running. Jessie and Pi-hole are all up to date.
I know this seems daft, but can someone try the test to see if it can be replicated!
I have 5 ports open, and it identified them correctly, but I don't have a port 4567 available.
I have run that same test and it's only seeing my router, it can't get past that.
OK. I think I need to detach everything from my network to see what device (if any) is opening the port and try to determine what device is opening the port. This could take a while...
OK.
After reducing my network to Router, PC and Pi-hole, and various re-boots, I have come to the conclusion that there is a problem with the routers firmware. Even without Pi-hole I am now getting errors with a different port (7574) which I believe is a port normally used by ISP provided routers for remote configuration etc. Very strange as the router isn't an ISP supplied router!!! I guess the problem is something not being initialised properly and has shown itself due to reboot/re-powering the router.
Thanks for your help.
Or the online scanner is buggy...
You could be right. Testing the ports that have shown errors using other on-line port testers show the ports to be closed, unless the bullguard (Shodan) one is more aggressive.
