PiSentinel — a browser extension for Pi-hole v6
Hey everyone,
I've been working on a browser extension called PiSentinel that connects to your Pi-hole v6 instance right from the toolbar.
What it does:
  • See your blocking stats at a glance (queries, blocked, percentage) from the popup
  • Toggle blocking on/off with a timer — no need to open the admin panel
  • Sidebar that shows all domains the current tab is loading, split into first-party and third-party
  • Add domains to your allowlist or denylist directly from the sidebar
  • Query log viewer
  • Supports multiple Pi-hole instances if you have more than one
  • 2FA/TOTP support
  • Your password is stored encrypted locally, never leaves your browser
Works on Firefox and Chrome/Edge (Manifest V3) Fully Tested on Firefox, chrome is pretty much untested from anyone. Free and open source.
Still early (v0.0.4) so feedback is very welcome. If you run into anything or have ideas, let me know here or open an issue on GitHub.
GitHub: GitHub - linx-systems/pi-sentinel: The Pi Hole Firefox Companion Extension!
Firefox Addons: PiSentinel – Holen Sie sich diese Erweiterung für 🦊 Firefox (de)
Cheers!
