The issue I am facing:
Domains blocked in my domain list are still passing through pihole since a while.
For example: tracking.justpremium.com which is on the blocklist but still gets through.
I've been running 2 piholes since years. Since an update/reinstall to Raspberry Pi OS the problem might have began.
Details about my system:
I'm not using pihole as dhcp server, my router does dhcp.
I've set the DNS servers to 192.168.1.2 and 192.168.1.3, both are piholes with the same config and blacklist (cloned with teleporter)
I've checked ipv6, checked my dns server settings, tried nslookup. No change. Removed all blocklists and added a single one again.
OK, this has been resolved. I think it had something to do with the groups, clients and lists configuration. I removed all groups , clients and reapplied the lists to all (the default) group. Rebooted the pi's and the blocking started working again.
Indeed, you configured two clients to be filtered by your group 2 (marketing), but the single blocklist you were using was assigned only to the default blocklist.
For using Pi-hole's group management, you may want to refer to our per-client blocking example.
The latter two of your outputs are NOT ok:
They should have been 0.0.0.0 for the two blocked domains, as your debug log shows your Pi-hole to is configured for its default blocking mode, not to return an IP.
It's also suspicious that the answer is for a public IP.
@Bucking_Horn I ran the nslookup from my windows 11 laptop at 192.168.1.124
No matter what domain name I lookup it shows my own external ip adres.
edit: Perhaps unrelated but I've got a domain name for my external ip address, mydomain.com. I also use some subdomains of that domain name in my internal network, home.mydomain.com for example. I've added home.mydomain.com in pihole's local DNS as a record that points the local ip adres 192.168.1.32. Which is a reverse proxy for several machines in my network pointing it to the correct server.
That IP seems to belong to British Telecom's btcentralplus.com.
Is that your public IP?
And how is that Windows machine connected to your network?
Do you run any AV or firewall on that machine?
Was that machine one of your two previous group management clients?
Do those two lookups for flurry.com and tracking.justpremium show up in your Pi-hole's Query Log as blocked?
@Bucking_Horn I obscured my own ip address a bit in my posts. But yes, the nslookup gives back my public ip address. My laptop is connected through wifi.
Yes, this laptop was one of my two previous group management clients. It does not have AV or a firewall.
Yes, I see them in the log and blocking seems to work again.
