System seemed to hang after rebooting via the CLI (sudo reboot) and power cycling. I was not able to ping. Power cycled for a third time and it came back to life. Anything look weird with my debug log? I am wondering if my SD card is corrupt.
I ran sudo reboot because dns names were not resolving after the update. After that the system seemed to fail to boot. It just kind of sat there and didn’t respond to a ping. Second manual power cycle, same thing. Then after the third attempt it seemed to boot as normal. There was an error in the system logs saying that there was a dirty bit and that the fs may be corrupted. Do you think that is the culprit?
I usually have had cards die outright, but never work intermittently like this.
