Thanks for the help. I tried the following, but the Pihole still only works intermittently:
I got a new SD card and installed a fresh copy of Raspbian with Pihole. I updated the dhcpcd.conf file to use a static IP address 192.168.0.2/24 and updated the router to use that for IPv4 DNS. I disabled IPv6 like before.
I've uploaded the debug log here: https://tricorder.pi-hole.net/NEQxUKC0/
I'm on a Mac and can see in my Network settings in System Prefs for DNS that my DNS server is in fact 192.168.0.2, so that seems correct.
Mac doesn't have ipconfig in terminal but I can run nslookup. Oddly, when I run it against one of the domains in the default Pihole blacklist (wizhumpgyros.com), it hits the correct DNS, but returns the actual IP address, whereas I think it should return a localhost IP instead:
$ nslookup wizhumpgyros.com
Server: 192.168.0.2
Address: 192.168.0.2#53
Non-authoritative answer:
Address: 82.192.82.227
This is also confirmed when I hit that URL in the browser -- I go directly to the page and it is not blocked.
On mac/linux, there is ifconfig. I'm not sure if it helps:
$ ifconfig -a
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
anpi1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether f2:71:89:26:9c:c1
inet6 fe80::f071:89ff:fe26:9cc1%anpi1 prefixlen 64 scopeid 0x4
media: none
status: inactive
anpi0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether f2:71:89:26:9c:c0
inet6 fe80::f071:89ff:fe26:9cc0%anpi0 prefixlen 64 scopeid 0x5
media: none
status: inactive
en3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether f2:71:89:26:9c:a0
media: none
status: inactive
en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether f2:71:89:26:9c:a1
media: none
status: inactive
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=460<TSO4,TSO6,CHANNEL_IO>
ether 36:2a:4f:77:ed:40
media: autoselect <full-duplex>
status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 36:2a:4f:77:ed:44
status: inactive
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x0
member: en1 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 8 priority 0 path cost 0
member: en2 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 9 priority 0 path cost 0
media: <unknown type>
status: inactive
ap1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
ether be:3e:53:96:71:72
media: autoselect
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=6463<RXCSUM,TXCSUM,TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
ether 9c:3e:53:96:71:72
inet6 fe80::1069:94d7:b861:fdc2%en0 prefixlen 64 secured scopeid 0xc
inet 192.168.0.248 netmask 0xffffff00 broadcast 192.168.0.255
media: autoselect
status: active
awdl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 8e:a6:4f:96:f0:f7
inet6 fe80::8ca6:4fff:fe96:f0f7%awdl0 prefixlen 64 scopeid 0xd
media: autoselect
status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
inet6 fe80::8ca6:4fff:fe96:f0f7%llw0 prefixlen 64 scopeid 0xe
media: autoselect
status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::e24b:1d0f:91f7:6979%utun0 prefixlen 64 scopeid 0xf
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::fa89:b9d4:6d89:743f%utun1 prefixlen 64 scopeid 0x10
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0x11
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::d14d:f6f5:d59c:9725%utun3 prefixlen 64 scopeid 0x12
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::60f1:784c:adc0:10b5%utun4 prefixlen 64 scopeid 0x13
