Pihole won't update. 'Web Admin repo is missing from system!'
Hello. Today I tried to update my pihole using ‘sudo pihole -up’. However, the following occurred:
[✓] Building dependency package pihole-meta.deb
[✓] Installing Pi-hole dependency package
[i] Checking for updates...
[i] Pi-hole Core:	update available
Error: Web Admin repo is missing from system!
Please re-run install script from https://pi-hole.net
I looked at some forums and tried this command:
sudo git config --global --add safe.directory /var/www/html/admin
but the results were the same. Any way to fix it? Thanks in advance.
Try to nuke the web repo and clone it again using these commands:
sudo rm -rf /var/www/html/admin
sudo git clone https://github.com/pi-hole/web.git /var/www/html/admin
After that, try to updated again.
That did the trick! Thank you very much!
