I have a new pi-hole setup that I am working on inside Docker. I am running into an issue getting pi-hole to work with unbound. It seems like the setup is refusing queries, and I am not certain if this is a template issue or an unbound config issue. I feel like I am very close to getting this to work, but I am missing something. I attached the error i get when i do a DNS lookup from my PC:
The stack that I am currently running is pasted below.
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
depends_on:
- unbound
ports:
# DNS Ports
- "53:53/tcp"
- "53:53/udp"
# Default HTTPs Port. FTL will generate a self-signed certificate
- "443:443/tcp"
environment:
# Set the appropriate timezone for your location
TZ: 'America/New_York'
# Set a password to access the web interface.
FTLCONF_webserver_api_password: ${Web_Server_Password}
# Docker's default `bridge` network setting the dns listening mode should be set to 'ALL'
FTLCONF_dns_listeningMode: 'ALL'
# DNS Upstream provider
FTLCONF_dns_upstreams: '127.0.0.1#53'
volumes:
# For persisting Pi-hole's databases and common configuration file
- './etc-pihole:/etc/pihole'
cap_add:
- SYS_NICE
restart: unless-stopped
unbound:
container_name: unbound
image: klutchell/unbound:latest
volumes:
- './etc-unbound:/etc/unbound'
You've created a DNS loop, feeding queries back to Pi-hole itself:
A loopback address like 127.0.0.1 points to the machine its attached to.
Within a Docker container, that is the container itself, and within the Pi-hole container, it is Pi-hole that listens on port 53.
You'd have to use your unbound container's IP instead.
As long as your Pi-hole container is using Docker's internal DNS resolver (i.e. no custom dns: section under pihole:), and if unbound and Pi-hole containers both run within the same Docker network (if the docker compose you've shared is complete, that should be the case), you should be able to just replace that line with:
Thanks for the response. That is what I initially did and why I tried the loop before asking for help. When I use the line
FTLCONF_dns_upstreams: unbound
I get the following DNS SERVER FAILURE error inside PiHole:
Cannot create NTP socket (Address family not supported by protocol), IPv6 NTP server not available
This causes the following to happen when I do a lookup from my PC:
C:\Users\Noah>nslookup google.com 192.168.1.164
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.164
I don’t have the NTP client or server running which is why I am stumped that it is trying to create the socket with IPv6. Also, on my host machine, I have disabled IPv6 for hardening which I have just verified.
Edit: I have also spun Pi-hole up in my environment without unbound, and that comes up perfectly.
But the powerdraw is probably way too high for what it does and can probably be replaced by a small Intel N100 NUC-like device with passive cooling so do yourself a favor and look into that
/Offtopic, but thought I should mention it just in case anyway…
In any case, Pi-hole's NTP server not starting wouldn't affect DNS resolution, so your DNS timeouts are tied to unbound, or perhaps something may be interfering with DNS on the client that ran the nslookup, as Server: UnKnown wouldn't happen if Pi-hole had been involved.
You could consider to apply klutchell's example configuration for running Pi-hole together with their Docker container, which would explicitly force Pi-hole and unbound on the same Docker internal network.
Thank you! It works now. I used the example configuration that you linked, adjusted it by adding in some of my settings like getting the DNS password from a .env, and tested it. it resolves google, uses unbound, and blocks a website I tested. Also, to answer your question about the NTP, I meant that I noted out the sections that set up the port and user for it. I am going to attach what my final configuration looks like, and mark your response as the answer as I am certain others may run into this issue.
# Config from https://github.com/klutchell/unbound-docker/tree/main/examples
volumes:
pihole:
services:
pihole:
ports:
# DNS Ports
- "53:53/tcp"
- "53:53/udp"
# Default HTTP Port
#- "80:80/tcp"
- "443:443/tcp"
# Uncomment the line below if you are using Pi-hole as your DHCP server
#- "67:67/udp"
# Uncomment the line below if you are using Pi-hole as your NTP server
#- "123:123/udp"
networks:
- default
environment:
# Sets upstream DNS to unbound sibling container
# If using Docker's default `bridge` network setting the dns listening mode should be set to 'all'
FTLCONF_dns_listeningMode: all
# Set a password to access the web interface. CREATE A .ENV VARIABLE
volumes:
# Uncomment the below if you have custom dnsmasq config files that you want to persist. Not needed for most starting fresh with Pi-hole v6. If you're upgrading from v5 you and have used this directory before, you should keep it enabled for the first v6 container start to allow for a complete migration. It can be removed afterwards. Needs environment variable FTLCONF_misc_etc_dnsmasq_d: 'true'
#- './etc-dnsmasq.d:/etc/dnsmasq.d'
cap_add:
# See https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
# Required if you are using Pi-hole as your DHCP server, else not needed
#- NET_ADMIN
# Required if you are using Pi-hole as your NTP client to be able to set the host's system time
#- SYS_TIME
# Optional, if Pi-hole should get some more processing time
- SYS_NICE
unbound:
networks:
- default
healthcheck:
# Use the drill wrapper binary to reduce the exit codes to 0 or 1 for healthchecks
test: ['CMD', 'drill-hc', '@127.0.0.1', 'dnssec.works']
interval: 30s
timeout: 30s
retries: 3
start_period: 30s
volumes:
#- /path/to/config:/etc/unbound/custom.conf.d
- './etc-unbound:/etc/unbound/conf.d'
networks:
default:
driver: bridge
I'd still recommend configuring your env vars to disable Pi-hole's NTP server for both IPv4 and IPv6 if you don't need it.
And you should probably consider dumping the entire healthcheck: section of your unbound container. dnssec.works works reasonably well for manually verifying that unbound is operational, but it also tends to be inaccessible every now and then, making it an inadequate fit for a health check.
