Pihole with Lets Encrypt issues
When requesting a new SSL cert from let's encrypt using dockers (jlesage/nginx-proxy-manager and pihole/pihole:latest) I should be able to request a new SSL cert
When trying to request a cert it fails. I've tried disabling all block groups (only using defaults), disabling and changing all DNS advance settings, changing upstream DNS from google to Cloudflare yet nothing works. Once I remove the pihole from the equation, it works perfectly. I'm also not seeing anything in the logs when trying to request it that says it was blocked.
Your debug token is: xcmqjyuy0k
Just tried again going to Disable set it to permanently, yet still get Internal Error when trying to get a cert for one of my sub-domains.
