Pihole + wireless hotspot
Hello,
I have raspberry Pi 3+ and I tried installing pihole along a wireless hotspot, but once I do the last step from this tutorial, pihole and internet doesn't work
add in /etc/dnsmasq.conf
interface=wlan0
dhcp-range=192.168.4.2,192.168.4.20,255.255.255.0,24h
ot
^ this part
This is the output of ifconfig
pi@raspberrypi:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.136 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 blabla prefixlen 64 scopeid 0x0
inet6 blabla prefixlen 64 scopeid 0x20
ether blabla txqueuelen 1000 (Ethernet)
RX packets 1516 bytes 350462 (342.2 KiB)
TX packets 5042 bytes 6059201 (5.7 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 231  bytes 18099 (17.6 KiB)
        TX packets 231  bytes 18099 (17.6 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.42.1  netmask 255.255.255.0  broadcast 192.168.42.255
        inet6 blabla  prefixlen 64  scopeid 0x20<link>
        RX packets 176  bytes 23509 (22.9 KiB)
        RX errors 0  dropped 1  overruns 0  frame 0
        TX packets 166  bytes 46481 (45.3 KiB)
What I'm trying to do is have internet from eth0 and then use pihole to block ads through the wireless hotspot.
What ip are u using for your wlan?
I think I eventually just disabled the dnsmasq and used pihole build in dhcpd
I'll have to check my recipe but I'm not at home
Feel free to pester me tomorrow and I'll look up and post more the most recent recipe I'm using
isee your issue i think since your wlan is at 192.168.42.1
the above dhcp-range should be
dhcp-range=192.168.42.2,192.168.42.20,255.255.255.0,24h
I've changed to dhcp-range=192.168.42.2,192.168.42.20,255.255.255.0,24h but still it doesn't work.
Maybe I'm not clear, I want to have a wireless hotspot with pihole's DHCP and have every client connecting to the hotspot to have ablock from pihole.
Here are my current settings:
$ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto eth0
auto wlan0
iface wlan0 inet static
  address 192.168.42.1
  wireless-power off
up iptables-restore < /etc/iptables.ipv4.nat
$ cat /etc/dnsmasq.conf
interface=wlan0
at the end of /etc/dhcpcd.conf I have this:
interface wlan0
static ip_address=192.168.42.1/24
static routers=192.168.42.1
$ cat /etc/resolv.conf
nameserver 127.0.0.1
search home
