darky
May 29, 2020, 4:20pm
1
I installed wireguard properly by using pivpn. But now, if I change the pihole listening behaviour in order to listen as well on wg0 to
Listen on all interfaces or
Listen on all interfaces, permit all origins
I cannot get a connection anymore to any website.
Any help is appreciated.
I believe wireguard and/or pivpn generate dedicated dnsmasq files in /etc/dnsmasq.d that interfere with the Pi-hole files in that same directory.
What is the content of the above folder?
jfb
May 29, 2020, 4:47pm
4
This command will show all the non-commented lines in that directory. Please post the output:
grep -v '#\|^$' -R /etc/dnsmasq.*
darky
May 29, 2020, 4:48pm
5
/etc/dnsmasq.conf:conf-dir=/etc/dnsmasq.d
/etc/dnsmasq.conf.dpkg-dist:dhcp-mac=set:client_is_a_pi,B8:27:EB:*:*:*
/etc/dnsmasq.conf.dpkg-dist:dhcp-reply-delay=tag:client_is_a_pi,2
/etc/dnsmasq.conf.old:conf-dir=/etc/dnsmasq.d
/etc/dnsmasq.d/02-wireguard.conf:interface=wg0
/etc/dnsmasq.d/02-dnscrypt.conf:proxy-dnssec
/etc/dnsmasq.d/02-pivpn.conf:addn-hosts=/etc/pivpn/hosts.wireguard
/etc/dnsmasq.d/02-pivpn.conf:interface=wg0
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/local.list
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/custom.list
/etc/dnsmasq.d/01-pihole.conf:localise-queries
/etc/dnsmasq.d/01-pihole.conf:no-resolv
/etc/dnsmasq.d/01-pihole.conf:cache-size=0
/etc/dnsmasq.d/01-pihole.conf:log-queries
/etc/dnsmasq.d/01-pihole.conf:log-facility=/var/log/pihole.log
/etc/dnsmasq.d/01-pihole.conf:local-ttl=2
/etc/dnsmasq.d/01-pihole.conf:log-async
/etc/dnsmasq.d/01-pihole.conf:domain-needed
/etc/dnsmasq.d/01-pihole.conf:bogus-priv
/etc/dnsmasq.d/01-pihole.conf:interface=eth0
/etc/dnsmasq.d/01-pihole.conf:server=/use-application-dns.net/
/etc/dnsmasq.d/10-pihole-extra.conf:proxy-dnssec
darky
May 29, 2020, 5:20pm
6
01-pihole.conf 02-dnscrypt.conf 02-pivpn.conf 02-stubby.conf 02-wireguard.conf 10-pihole-extra.conf README
Any help?
Leave it on "Listen only on interface eth0
Any interface=
directive in the grep
output restricts the pihole-FTL
daemon to answer only on that interface instead of default answer on all.
When you set "Listen on all interfaces
", Pi-hole will remove its interface=
directive leaving the ones in 02-wireguard.conf
and 02-pivpn.conf
still active and thus restricting to only answer on the wg0
interface.
You can test with for example:
host pi.hole <ETH0_IP_ADDRESS>
host pi.hole <WG0_IP_ADDRESS>
EDIT: I didnt notice at first but the directive is also in 02-pivpn.conf
system
Closed
June 19, 2020, 6:38pm
8
