Yes, that's what I thought too.
I just tried the commands you kindly provided but there is no change with the web interface sadly.
Whats output now ?
sudo grep -v '^\s*#\|^\s*$' /etc/lighttpd/{lighttpd,external}.conf
And for below:
date && sudo service lighttpd status
Output for first command:
root@pi:/home/ape# sudo grep -v '^\s*#|^\s*$' /etc/lighttpd/{lighttpd,external}.conf
/etc/lighttpd/lighttpd.conf:server.modules = (
/etc/lighttpd/lighttpd.conf: "mod_access",
/etc/lighttpd/lighttpd.conf: "mod_accesslog",
/etc/lighttpd/lighttpd.conf: "mod_auth",
/etc/lighttpd/lighttpd.conf: "mod_expire",
/etc/lighttpd/lighttpd.conf: "mod_compress",
/etc/lighttpd/lighttpd.conf: "mod_redirect",
/etc/lighttpd/lighttpd.conf: "mod_setenv",
/etc/lighttpd/lighttpd.conf: "mod_rewrite"
/etc/lighttpd/lighttpd.conf:)
/etc/lighttpd/lighttpd.conf:server.document-root = "/var/www/html"
/etc/lighttpd/lighttpd.conf:server.error-handler-404 = "/pihole/index.php"
/etc/lighttpd/lighttpd.conf:server.upload-dirs = ( "/var/cache/lighttpd/uploads" )
/etc/lighttpd/lighttpd.conf:server.errorlog = "/var/log/lighttpd/error.log"
/etc/lighttpd/lighttpd.conf:server.pid-file = "/var/run/lighttpd.pid"
/etc/lighttpd/lighttpd.conf:server.username = "www-data"
/etc/lighttpd/lighttpd.conf:server.groupname = "www-data"
/etc/lighttpd/lighttpd.conf:server.port = 80
/etc/lighttpd/lighttpd.conf:accesslog.filename = "/var/log/lighttpd/access.log"
/etc/lighttpd/lighttpd.conf:accesslog.format = "%{%s}t|%V|%r|%s|%b"
/etc/lighttpd/lighttpd.conf:index-file.names = ( "index.php", "index.html", "index.lighttpd.html" )
/etc/lighttpd/lighttpd.conf:url.access-deny = ( "~", ".inc", ".md", ".yml", ".ini" )
/etc/lighttpd/lighttpd.conf:static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
/etc/lighttpd/lighttpd.conf:compress.cache-dir = "/var/cache/lighttpd/compress/"
/etc/lighttpd/lighttpd.conf:compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
/etc/lighttpd/lighttpd.conf:mimetype.assign = ( ".png" => "image/png",
/etc/lighttpd/lighttpd.conf: ".jpg" => "image/jpeg",
/etc/lighttpd/lighttpd.conf: ".jpeg" => "image/jpeg",
/etc/lighttpd/lighttpd.conf: ".html" => "text/html",
/etc/lighttpd/lighttpd.conf: ".css" => "text/css; charset=utf-8",
/etc/lighttpd/lighttpd.conf: ".js" => "application/javascript",
/etc/lighttpd/lighttpd.conf: ".json" => "application/json",
/etc/lighttpd/lighttpd.conf: ".txt" => "text/plain",
/etc/lighttpd/lighttpd.conf: ".svg" => "image/svg+xml" )
/etc/lighttpd/lighttpd.conf:include_shell "/usr/share/lighttpd/use-ipv6.pl " + server.port
/etc/lighttpd/lighttpd.conf:include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include \"%p\"\n' 2>/dev/null"
/etc/lighttpd/lighttpd.conf:$HTTP["url"] =~ "^/admin/" {
/etc/lighttpd/lighttpd.conf: setenv.add-response-header = (
/etc/lighttpd/lighttpd.conf: "X-Pi-hole" => "The Pi-hole Web interface is working!",
/etc/lighttpd/lighttpd.conf: "X-Frame-Options" => "DENY"
/etc/lighttpd/lighttpd.conf: )
/etc/lighttpd/lighttpd.conf: $HTTP["url"] =~ ".ttf$" {
/etc/lighttpd/lighttpd.conf: setenv.add-response-header = ( "Access-Control-Allow-Origin" => "*" )
/etc/lighttpd/lighttpd.conf: }
/etc/lighttpd/lighttpd.conf:}
/etc/lighttpd/lighttpd.conf:$HTTP["url"] =~ "^/admin/\.(.*)" {
/etc/lighttpd/lighttpd.conf: url.access-deny = ("")
/etc/lighttpd/lighttpd.conf:include_shell "cat external.conf 2>/dev/null"
root@pi:/home/ape#
Output for second command:
root@pi:/home/ape# date && sudo service lighttpd status
Wed 13 May 18:19:18 BST 2020
β lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-05-13 18:11:01 BST; 8min ago
Main PID: 32132 (lighttpd)
Tasks: 1 (limit: 4915)
Memory: 1.5M
CGroup: /system.slice/lighttpd.service
ββ32132 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
May 13 18:11:01 pi.hole systemd[1]: Starting Lighttpd Daemon...
May 13 18:11:01 pi.hole lighttpd[32124]: 2020-05-13 18:11:01: (server.c.1493) WARNING: unknown config-key: alias.url (ignored)
May 13 18:11:01 pi.hole systemd[1]: Started Lighttpd Daemon.
May 13 18:11:01 pi.hole systemd[1]: /lib/systemd/system/lighttpd.service:6: PIDFile= references path below legacy directory /var/run/, updating /var/run/lighttpd.pid β /run
May 13 18:11:02 pi.hole systemd[1]: /lib/systemd/system/lighttpd.service:6: PIDFile= references path below legacy directory /var/run/, updating /var/run/lighttpd.pid β /run
curl -Iv http://localhost/admin/
Below is the output:
root@pi:/home/ape# curl -Iv http://localhost/admin/
* Expire in 0 ms for 6 (transfer 0x111ee40)
* Expire in 1 ms for 1 (transfer 0x111ee40)
* Expire in 0 ms for 1 (transfer 0x111ee40)
* Expire in 2 ms for 1 (transfer 0x111ee40)
* Trying ::1...
* TCP_NODELAY set
* Expire in 149998 ms for 3 (transfer 0x111ee40)
* Expire in 200 ms for 4 (transfer 0x111ee40)
* Connected to localhost (::1) port 80 (#0)
> HEAD /admin/ HTTP/1.1
> Host: localhost
> User-Agent: curl/7.64.0
> Accept: */*
< HTTP/1.1 403 Forbidden
< Content-Type: text/html
< X-Pi-hole: The Pi-hole Web interface is working!
< X-Frame-Options: DENY
< Content-Length: 341
Content-Length: 341
< Date: Wed, 13 May 2020 17:25:03 GMT
< Server: lighttpd/1.4.53
* Connection #0 to host localhost left intact
root@pi:/home/ape#
Ow move that backup file away to your own home folder (it might still get loaded):
sudo mv /etc/lighttpd/lighttpd.conf.bak ~
And restart:
sudo service lighttpd restart
And do curl
again.
Thanks. Here's the Curl output again after moving the backup file:
* Expire in 0 ms for 6 (transfer 0x2144e40)
* Expire in 1 ms for 1 (transfer 0x2144e40)
* Expire in 0 ms for 1 (transfer 0x2144e40)
* Expire in 2 ms for 1 (transfer 0x2144e40)
* Trying ::1...
* TCP_NODELAY set
* Expire in 149998 ms for 3 (transfer 0x2144e40)
* Expire in 200 ms for 4 (transfer 0x2144e40)
> Host: localhost
> Accept: */*
Content-Length: 341
< Date: Wed, 13 May 2020 17:30:58 GMT
root@pi:/home/ape#
Try below:
Just got an error while running the first command:
root@pi:/home/ape# sudo rm /var/www/html/admin
rm: cannot remove '/var/www/html/admin': Is a directory
root@pi:/home/ape#
sudo rm -r /var/www/html/admin
sudo git clone https://github.com/pi-hole/AdminLTE.git /var/www/html/admin
pihole -r # and select repair
The commands worked this time. Still no luck with the admin interface though. There's a few PHP Warnings, could this be the issue? Below is the output of the commands:
root@pi:/home/ape# sudo rm -r /var/www/html/admin
root@pi:/home/ape# sudo git clone https://github.com/pi-hole/AdminLTE.git /var/www/html/admin
Cloning into '/var/www/html/admin'...
remote: Enumerating objects: 178, done.
remote: Counting objects: 100% (178/178), done.
remote: Compressing objects: 100% (98/98), done.
remote: Total 22975 (delta 90), reused 148 (delta 80), pack-reused 22797
Receiving objects: 100% (22975/22975), 29.32 MiB | 3.01 MiB/s, done.
Resolving deltas: 100% (12085/12085), done.
root@pi:/home/ape# pihole -r
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
PHP Warning: PHP Startup: Unable to load dynamic library 'mysqli' (tried: /usr/lib/php/20190902/mysqli (/usr/lib/php/20190902/mysqli: cannot open shared object file: No such file or directory), /usr/lib/php/20190902/mysqli.so (/usr/lib/php/20190902/mysqli.so: undefined symbol: mysqlnd_global_stats)) in Unknown on line 0
PHP Warning: Module 'exif' already loaded in Unknown on line 0
PHP Warning: Module 'mbstring' already loaded in Unknown on line 0
[i] Existing PHP installation detected : PHP version 7.4.5
[i] Repair option selected
[β] Disk space check
[β] Update local cache of available packages
[β] Checking apt-get for upgraded packages... up to date!
[β] Checking for dhcpcd5
[β] Checking for git
[β] Checking for iproute2
[β] Checking for whiptail
[i] SELinux not detected
[i] Performing reconfiguration, skipping download of local repos
[β] Resetting repository within /etc/.pihole...
[β] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[β] Checking for cron
[β] Checking for curl
[β] Checking for dnsutils
[β] Checking for iputils-ping
[β] Checking for lsof
[β] Checking for netcat
[β] Checking for psmisc
[β] Checking for sudo
[β] Checking for unzip
[β] Checking for wget
[β] Checking for idn2
[β] Checking for sqlite3
[β] Checking for libcap2-bin
[β] Checking for dns-root-data
[β] Checking for lighttpd
[β] Checking for php7.4-common
[β] Checking for php7.4-cgi
[β] Checking for php7.4-sqlite3
[β] Checking for php7.4-xml
[β] Checking for php-intl
[β] Enabling lighttpd service to start on reboot...
[β] Checking for user 'pihole'
[i] FTL Checks...
[β] Detected 32bit (i686) architecture
[i] Latest FTL Binary already installed (v5.0). Confirming Checksum...
[i] Checksum correct. No need to download!
/etc/.pihole/automated install/basic-install.sh: line 1892: usermod: command not found
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[β] Restarting lighttpd service...
[i] Restarting services...
[β] Enabling pihole-FTL service to start on reboot...
[β] Restarting pihole-FTL service...
[β] Deleting existing list cache
[β] Pulling blocklist source list into range
[β] Preparing new gravity database
[β] Status: Retrieval successful
[i] Received 57536 domains
[i] Target: https://mirror1.malwaredomains.com/files/justdomains
[i] Received 26857 domains
[i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
[i] Received 34 domains
[i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
[i] Received 2701 domains
[β] Storing downloaded domains in new gravity database
[β] Building tree
[β] Swapping databases
[i] Number of gravity domains: 87128 (84686 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 0
[i] Number of regex whitelist filters: 0
[β] Flushing DNS cache
[β] Cleaning up stray matter
[β] DNS service is running
[β] Pi-hole blocking is Enabled
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v5.0.
Current AdminLTE version is v5.0.
Current FTL version is v5.0.
root@pi:/home/ape#
Seems the host got allot of issues.
Dont know where to start
dpkg --get-selections *sql* *php*
I guess those PHP Warnings shouldn't be there. Here's the output of the command:
root@pi:/home/ape# dpkg --get-selections *sql* *php*
dpkg: no packages found matching mysql-apt-config_0.8.13-1_all.deb
dpkg: no packages found matching mysql-apt-config_0.8.13-1_all.deb.1
dpkg: no packages found matching index.php
dpkg: no packages found matching phpMyAdmin-4.9.0.1-all-languages
dpkg: no packages found matching phpMyAdmin-4.9.0.1-all-languages.tar.gz
root@pi:/home/ape#
Hmmm this was expected (or with similar versions):
pi@ph5:~ $ dpkg --get-selections *sql* *php*
libsqlite3-0:armhf install
php-sqlite3 install
php7.3-sqlite3 install
sqlite3 install
php-cgi install
php-common install
php-intl install
php-sqlite3 install
php7.3-cgi install
php7.3-cli install
php7.3-common install
php7.3-intl install
php7.3-json install
php7.3-opcache install
php7.3-readline install
php7.3-xml install
Looks like something seriously wrong with your setup that I dont have a quick fix for.
Sorry.
Can try the Debian support forums.
Thank you so much for trying, really appreciate your help. I'm really not sure how my setup is such a mess - I am not a high linux user so I only installed Debian and Pi-Hole. Clearly something happened though.
I think I might just re-install Debian tomorrow. Hopefully this will solve all of the issues.
Thanks again
That is because the command arguments globbed against some files in the current dir, please try to quote them to get the expected output:
dpkg --get-selections '*sql*' '*php*'
It might be simply a PHP modules version mismatch, but let's see which ones you've installed.
Thanks for yourr reply, looks like it came up with something this time:
ape@pi:~$ su root
Password:
root@pi:/home/ape# dpkg --get-selections '*sql*' '*php*'
libaprutil1-dbd-sqlite3:i386 install
libdbd-mysql-perl:i386 install
libsqlite3-0:i386 install
lighttpd-modules-mysql install
mysql-apt-config install
mysql-common install
php-sqlite3 install
php7.0-mysql install
php7.0-sqlite3 install
php7.3-mysql install
php7.4-mysql install
php7.4-sqlite3 install
sqlite3 install
libapache2-mod-php7.4 install
php install
php-cgi install
php-common install
php-intl install
php-pear install
php-sqlite3 install
php-xml install
php7.0-cgi install
php7.0-cli install
php7.0-common install
php7.0-json install
php7.0-opcache install
php7.0-readline install
php7.0-xml install
php7.3 install
php7.3-cgi install
php7.3-cli install
php7.3-json install
php7.4 install
php7.4-cgi install
php7.4-cli install
php7.4-common install
php7.4-curl install
php7.4-intl install
php7.4-json install
php7.4-mbstring install
php7.4-opcache install
php7.4-readline install
php7.4-xml install
php7.4-zip install
root@pi:/home/ape#
Of course.
Stupid me
Thats a whole lot of different versions for PHP.
It is possible to run different PHP versions alongside each other if software utilising PHP is configured properly.
But can complicate matters.
Can start with the missing files:
Search what package the missing files belongs to:
dpkg -S /usr/lib/php/20190902/mysqli.so
And try reinstall <PACKAGE_NAME>
from apt
cache:
sudo apt install --reinstall <PACKAGE_NAME>
If that dont fix, try purge the package with dpkg
(read all the way down before do so):
sudo dpkg -P <PACKAGE_NAME>
And resinstall:
If that dont fix, you can try purge with apt
sudo apt purge <PACKAGE_NAME>
And resinstall:
Difference between purging is that dpkg -P
only purges the files contained in the package.
And apt purge
is going to purge other packages that depend on the purged package as well.
This sometimes can make a bit of mess.
And also mind when purging packages it can break other software that have configured the package because purging also means the config files gets removed.
I reinstalled PHP lots of times - I was following some tutorial I found on the internet to try and fix my issue before I posted this thread.
I have run those commands for all of the missing files but I am still getting the PHP Warnings and the issue with lighthttp still persists. I have restarted the server also.
