PiHole functioning properly. Accessible via IP address/terminal. Dashboard updating regularly. Running:
Rpi 4 Model B
DietPi v8.7
Pi-Hole 5.11.4
Unbound
Doesn't seem to be doing anything. I have access to the admin panel but Pi Hole isn't blocking any queries. Not sure what happened after my power went out, but as soon as it came back on, the Pi Hole stopped functioning properly.
It was intermittently blocking queries, but not at the rate that it had been before. It was just a handful compared to hundreds when it was working properly.
Here is the output of the commands you asked me to run. I had to change 128 to 129 because the RPi stopped working so I unplugged it and it found another IP address when it restarted:
I'm a very, very new person to RaspberryPi's and PiHole in general. How... do I run a command from a client?
Sorry this is probably the most basis question I could ask. I really just followed a setup guide for this whole them. Not entirely sure of anything outside of that guide.
If you use Windows you need to type those commands in the command line tool (terminal).
__
Background:
From the debug log I can see that your router is advertising it's own IP as DNS server to the clients via DHCP. This means all DNS queries go to the router instead of Pi-hole.
Timeout: 10 seconds
* Received 548 bytes from eth0:192.168.1.1
Offered IP address: 192.168.1.29
Server IP address: N/A
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
lease-time: 86400 ( 1d )
netmask: 255.255.255.0
router: 192.168.1.1
dns-server: 192.168.1.1
--- end of options ---
Witht the nslookup commands we could verify this. But you could also go on and change the DHCP settings in your router to advertise Pi-hole's IP as DNS server. Just make sure that you disconnect your devices from your network after you made DHCP changes to pick up the new settings.
Ohhhhh okay. Sorry, I thought there was another command line for interacting directly with the RPi that I wasn't aware of. Here's what I get when I enter those into Command Prompt:
This may be part of your solution but is there a way to keep a specific IP address open on my router so that DietPi/RPi doesn't continually switch to randomly new/different IPs every day? Does it matter if that happens or not?
It depends on how your router handles it. You'll have to go into your router's settings and find if it will let you set custom DNS servers for the local LAN devices and change it there. These may be separate from DNS settings your router is using for its WAN connection.
A vast majority of routers allow this. The wifi I'm using is locked behind an app. and in that app, I then have to log in. I don't know anything about the account and it's isp equipment, not custom purchased.
Simce your getting into this, I like to let folks know that your smart devices will (like wifi-connected smart tv) will usually not let you change dns manually.
So, I have a tiny wifi usb that uses it, and, with windows, in two clicks, I have my own 15-20ft range network for these devices.
I think I'll add another wifi router and just use it in place. Gotta block that telemetry. When roku refuses to tell its customer base what information is collected, well you do the math!
I seem to have gotten it working. I believe I must've been focusing on Pi-Hole instead of DietPi itself when I was trying to configure the static IP. I reinstalled almost everything and started from scratch, and specified the static IP I wanted from the beginning.
Hopefully this is the last time I run into this sort of issue, but I just wanna say thank you to everyone who replied because you guys helped me out a ton!
