Adas
March 10, 2025, 9:20pm
1
Pihole has blocked almost nothing since the upgrade to v6, currently it only blocks *.cloud.com addresses. Worked fine before the update, no longer works after the update. It doesn't work on all my devices. Gravity updated.
Debug log: https://tricorder.pi-hole.net/CahVkRSX/
Run from a client you expect to use Pi-hole for DNS, what's the output of:
nslookup pi.hole
nslookup flurry.com
nslookup pi-hole.net
How do the latter two register in Pi-hole's Query Log ?
Hi Adas, double check you've not disabled the default group by accident in groups, this happened to me and was only blocking that domain.
That is indeed the case - enabled is 0:
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 0 Default 2025-02-21 17:58:47 2025-02-21 18:14:37 The default group
Adas
March 14, 2025, 6:20pm
5
Thank you. You solve my problem.
system
Closed
April 4, 2025, 6:21pm
6
