Tried another repair before the running output for your items. Everything looked OK. Here is output from repair.
[i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u3
[i] Repair option selected
[✓] Disk space check
[✓] Checking apt-get for upgraded packages... 23 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[✓] Checking for apt-utils
[✓] Checking for dialog
[✓] Checking for debconf
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[i] Performing reconfiguration, skipping download of local repos
[✓] Resetting repository within /etc/.pihole...
[✓] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for resolvconf
[✓] Checking for lighttpd
[✓] Checking for php7.0-common
[✓] Checking for php7.0-cgi
[✓] Checking for php7.0-sqlite3
[✓] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[✓] Detected ARM-hf architecture (armv7+)
[i] Latest FTL Binary already installed (v4.3). Confirming Checksum...
[i] Checksum correct. No need to download!
[✓] Installing scripts from /etc/.pihole
[✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Installing blocking page...
[✓] Creating directory for blocking page, and copying files
[✗] Backing up index.lighttpd.html
[✓] Installing sudoer file
[✓] Installing latest Cron script
[✓] Installing latest logrotate script
[i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
[✓] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[✓] Restarting lighttpd service...
[i] Restarting services...
> pi@rpi : ~ $ pihole -up
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] Web Interface: up to date
[i] FTL: up to date
[✓] Everything is up to date!
pi@rpi : ~ $ pihole -v
Pi-hole version is v4.3 (Latest: v4.3)
AdminLTE version is v4.3 (Latest: v4.3)
FTL version is v4.3 (Latest: v4.3)
pi@rpi : ~ $ pihole status
[✗] DNS service is NOT running
pi@rpi : ~ $ pihole enable
[i] Blocking already enabled, nothing to do
pi@rpi : ~ $ /usr/bin/pihole-FTL -v
v4.3
pi@rpi : ~ $ sudo service pihole-FTL restart
Job for pihole-FTL.service failed because the control process exited with error code.
See "systemctl status pihole-FTL.service" and "journalctl -xe" for details.
pi@rpi : ~ $ systemctl status pihole-FTL.service
● pihole-FTL.service
Loaded: loaded (/etc/init.d/pihole-FTL; generated; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2019-05-20 17:20:33 EDT; 4min 35
Process: 5593 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=203/
May 20 17:20:33 rpi systemd[1]: Starting pihole-FTL.service...
May 20 17:20:33 rpi systemd[1]: pihole-FTL.service: Control process exited, code
May 20 17:20:33 rpi systemd[1]: Failed to start pihole-FTL.service.
May 20 17:20:33 rpi systemd[1]: pihole-FTL.service: Unit entered failed state.
May 20 17:20:33 rpi systemd[1]: pihole-FTL.service: Failed with result 'exit-cod
lines 1-11/11 (END)
pi@rpi : ~ $ journalctl -xe
-- Support: Debian -- User Support
-- Unit pihole-FTL.service has begun starting up.
May 20 17:20:33 rpi systemd[5593]: pihole-FTL.service: Failed at step EXEC spawn
-- Subject: Process /etc/init.d/pihole-FTL could not be executed
-- Defined-By: systemd
-- The process /etc/init.d/pihole-FTL could not be executed and failed.
-- The error number returned by this process is 8.
-- Subject: Unit pihole-FTL.service has failed
-- Unit pihole-FTL.service has failed.
-- The result is failed.
May 20 17:20:33 rpi sudo[5584]: pam_unix(sudo:session): session closed for user
lines 2904-2926/2926 (END)
pi@rpi : ~ $ journalctl --no-pager -u pihole-FTL
-- Logs begin at Thu 2016-11-03 13:16:43 EDT, end at Mon 2019-05-20 17:20:33 EDT. --
May 20 01:38:47 rpi systemd[1]: Starting pihole-FTL.service...
May 20 01:38:48 rpi systemd[1]: pihole-FTL.service: Control process exited, code=exited status=203
May 20 01:38:48 rpi systemd[1]: Failed to start pihole-FTL.service.
May 20 01:38:48 rpi systemd[1]: pihole-FTL.service: Unit entered failed state.
May 20 01:38:48 rpi systemd[1]: pihole-FTL.service: Failed with result 'exit-code'.
May 20 17:20:33 rpi systemd[1]: pihole-FTL.service: Control process exited, code=exited status=203
May 20 17:20:33 rpi systemd[1]: pihole-FTL.service: Failed with result 'exit-code'.
