Hello,
When I do this command, I have this erroe
[β] Supported OS detected
[β] Update local cache of available packages
[β] Building dependency package pihole-meta.deb
[β] Installing Pi-hole dependency package
[i] Checking for updates...
[i] Pi-hole Core: up to date
fatal : impossible d'accΓ©der Γ 'https://github.com/pi-hole/web.git/' : Could not resolve host: github.com
Error: Unable to update local repository. Contact Pi-hole Support.
[β] DNS resolution is currently unavailable
[β] DNS resolution is available
Why ?
When I try sudo pihole repair, I have this error :
[β] Retrieval of supported OS list failed. dig failed with return code 10.
Unable to determine if the detected OS (Debian 12) is supported
Possible causes for this include:
- Firewall blocking DNS lookups from Pi-hole device to ns1.pi-hole.net
- DNS resolution issues of the host system
- Other internet connectivity issues
My internet connection is OK.
Regards
