Pihole -up wants to add Ubuntu's universe repo to Raspbian Buster?
Please ensure that you are running the latest version of the beta code.
Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Problem with Beta 5.0:
running pihole -up yesterday worked fine but today running pihole -up presents me with the following.
selecting yes results in the following error
  [i] Enabling universe package repository for Ubuntu Bionic
  [✓] Backed up current configuration to /etc/apt/sources.list.backup
Traceback (most recent call last):
  File "/usr/bin/add-apt-repository", line 95, in <module>
    sp = SoftwareProperties(options=options)
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
    self.reload_sourceslist()
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
    self.distro.get_sources(self.sourceslist)
  File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
    (self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Raspbian/buster
not sure why it's trying to enable universe package repository for Ubuntu Bionic as I'm using
output of cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
output of uname -a
Linux ns1 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
I don't have any Ubuntu sources enabled. I use the WireGuard repo since I can't seem to get WireGuard any other way but i don't use any sources that provide default Ubuntu packages.
content of /etc/apt/sources.list
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
# deb http://ppa.launchpad.net/qbittorrent-team/qbittorrent-stable/ubuntu bionic main
# deb-src http://ppa.launchpad.net/qbittorrent-team/qbittorrent-stable/ubuntu bionic main
# deb http://ppa.launchpad.net/wireguard/wireguard/ubuntu bionic main
# deb-src http://ppa.launchpad.net/wireguard/wireguard/ubuntu bionic  main
output of pihole -v
  Pi-hole version is release/v5.0 v4.3.5-493-g393c773 (Latest: v4.4)
  AdminLTE version is release/v5.0 v4.3.2-488-g34d9942 (Latest: v4.3.3)
  FTL version is release/v5.0 vDev-5ad55e8 (Latest: v4.3.1)
https://tricorder.pi-hole.net/v4chwhnrk8
What's in /etc/apt/sources.list.d/?
https://github.com/pi-hole/pi-hole/blob/release/v5.0/automated%20install/basic-install.sh#L193
That's what is triggering it. I'll see if we can ignore commented lines, but really you shouldn't have bionic repos on buster.
/etc/apt/sources.list.d $ ls -la
total 24
drwxr-xr-x 2 root root 4096 Apr 25 16:49 .
drwxr-xr-x 7 root root 4096 Apr 28 14:17 ..
-rw-r--r-- 1 root root   74 Apr 25 16:49 docker.list
-rw-r--r-- 1 root root   90 Apr 15  2019 nordvpn.list
-rw-r--r-- 1 root root   60 Apr 20 16:55 pivpn-bullseye.list
-rw-r--r-- 1 root root  187 Feb 13 09:57 raspi.list
/etc/apt/sources.list.d $ cat docker.list
deb [arch=armhf] https://download.docker.com/linux/raspbian buster stable
/etc/apt/sources.list.d $ cat nordvpn.list
# NordVPN releases, stable
deb https://repo.nordvpn.com/deb/nordvpn/debian stable main
/etc/apt/sources.list.d $ cat pivpn-bullseye.list
deb http://raspbian.raspberrypi.org/raspbian/ bullseye main
/etc/apt/sources.list.d $ cat raspi.list
deb http://archive.raspberrypi.org/debian/ buster main
#deb-src http://archive.raspberrypi.org/debian/ buster main
Can confirm removing those line fixed the issue
@bcambl Should we do bionic and focal or what ever 20.04 is named? Might as well get both in the same PR.
I think you @ the wrong handle :squinting_face_with_tongue:
