When running pihole -up, the existing lighttpd.conf server.port is set back to 80 - could this be made to retain the exisiting port, as sometimes people use something other than 80 (in my case I use 8080 for lighttpd so that I can run apache alongside on port 80)
We should probably add this as an FAQ somewhere I guess, but the answer you are looking for is at the bottom of this post:
Ah, I had tried that but was missing the := , thanks
