Pihole -up Giving Cert Error for objects.githubusercontent.com
I noticed my Ubuntu install has an update for pihole FTL.
Sadly it's failing with a cert error about objects.githubusercontent.com
Expect pihole -up update command to run without any issues.
will@pihole:~$ pihole -up
  [i] Existing PHP installation detected : PHP version 8.1.2-1ubuntu2.13
  [✓] Checking for git
  [✓] Checking for iproute2
  [✓] Checking for dialog
  [✓] Checking for ca-certificates
  [i] Checking for updates...
  [i] Pi-hole Core:     up to date
  [i] Web Interface:    up to date
curl: (60) SSL: no alternative certificate subject name matches target host name 'objects.githubusercontent.com'
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
  [i] FTL:              update available
  [i] FTL out of date, it will be updated by the installer.
  [✓] Root user check
        .ccccc:,.
         :cccclll:.      ..,,
          :ccccclll.   ;ooodc
           'ccll:;ll .oooodc
             .;cll.;;looo:.
  [i] SELinux not detected
  [i] Checking for / installing Required dependencies for OS Check...
  [✓] Checking for grep
  [✓] Checking for dnsutils
  [✓] Supported OS detected
  [i] Checking for / installing Required dependencies for this install script...
  [i] Performing unattended setup, no dialogs will be displayed
  [i] Performing reconfiguration, skipping download of local repos
  [✓] Resetting repository within /etc/.pihole...
  [✓] Resetting repository within /var/www/html/admin...
  [i] Checking for / installing Required dependencies for Pi-hole software...
  [✓] Checking for cron
  [✓] Checking for curl
  [✓] Checking for iputils-ping
  [✓] Checking for psmisc
  [✓] Checking for sudo
  [✓] Checking for unzip
  [✓] Checking for idn2
  [✓] Checking for libcap2-bin
  [✓] Checking for netcat-openbsd
  [✓] Checking for procps
  [✓] Checking for jq
  [✓] Checking for lighttpd
  [✓] Checking for php8.1-common
  [✓] Checking for php8.1-cgi
  [✓] Checking for php8.1-sqlite3
  [✓] Checking for php8.1-xml
  [✓] Checking for php8.1-intl
  [✓] Enabling lighttpd service to start on reboot...
  [i] FTL Checks...
  [✓] Detected x86_64 processor
  [i] Latest FTL Binary already installed (v5.23). Confirming Checksum...
  [i] Corruption detected...
  [i] Downloading and Installing FTL...curl: (60) SSL: no alternative certificate subject name matches target host name 'objects.githubusercontent.com'
   Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-linux-x86_64 not found
  [✗] FTL Engine not installed
The upload failed as well.
[✓] ** FINISHED DEBUGGING! **
    * Error message: curl: (60) SSL: no alternative certificate subject name matches target host name 'tricorder.pi-hole.net'
   * A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
Thanks for the assistance,
Will
https://bugs.launchpad.net/ubuntu/+source/curl/+bug/2028170
The new fixed curl is out:
Unpacking curl (7.81.0-1ubuntu1.13) over (7.81.0-1ubuntu1.11)
Unpacking libcurl4:amd64 (7.81.0-1ubuntu1.13) over (7.81.0-1ubuntu1.11)
Unpacking libcurl3-gnutls:amd64 (7.81.0-1ubuntu1.13) over (7.81.0-1ubuntu1.11)
Now good to go.
