I turn again trustfully to the super community!
Unfortunately I can not update my Pi-Hole for months.
I have already checked all the descriptive possibilities, I can say that they do not apply.
I get the following error:
[i] Existing PHP installation detected : PHP version 7.4.28
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[✓] Checking for ca-certificates
[i] Checking for updates...
fatal: unable to access 'GitHub - pi-hole/pi-hole: A black hole for Internet advertisements': Could not resolve host: github.com
[i] Pi-hole Core: up to date
fatal: unable to access 'GitHub - pi-hole/web: Pi-hole Dashboard for stats and more': Could not resolve host: github.com
[i] Web Interface: up to date
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Checking for / installing Required dependencies for OS Check...
[✓] Checking for grep
[✓] Checking for dnsutils
[✗] Retrieval of supported OS list failed. dig failed with return code 10.
Unable to determine if the detected OS (Raspbian 11) is supported
Possible causes for this include:
- Firewall blocking certain DNS lookups from Pi-hole device
- ns1.pi-hole.net being blocked (required to obtain TXT record from versions.pi-hole.net containing supported operating systems)
- Other internet connectivity issues
https://docs.pi-hole.net/main/prerequesites/#supported-operating-systems
If you wish to attempt to continue anyway, you can try one of the following commands to skip this check:
e.g: If you are seeing this message on a fresh install, you can run:
curl -sSL https://install.pi-hole.net | sudo PIHOLE_SKIP_OS_CHECK=true bash
If you are seeing this message after having run pihole -up:
sudo PIHOLE_SKIP_OS_CHECK=true pihole -r
(In this case, your previous run of pihole -up will have already updated the local repository)
It is possible that the installation will still fail at this stage due to an unsupported configuration.
If that is the case, you can feel free to ask the community on Discourse with the Community Help category:
https://discourse.pi-hole.net/c/bugs-problems-issues/community-help/
Can anyone help me?
