Running pihole -up update FTL
[i] Downloading and Installing FTL...curl: (22) The requested URL returned error: 404
Error: URL https://github.com/pi-hole/FTL/releases/download/v4.2.3/tbd not found
https://tricorder.pi-hole.net/kxb8plas0k !
It seems that the -up process is trying to download from a directory (/tbd) which is a placeholder. The command does work
curl -sSL https://github.com/pi-hole/FTL/releases/download/v4.2.3/pihole-FTL-arm-linux-gnueabihf -o pihole-FTL
jfb
March 17, 2019, 3:51pm
2
You are running on the dev branch of FTL.
[✓] FTL: vDev-aae487e (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
Run the following to move FTL to the master and get the latest version:
pihole checkout ftl master
Edit - just noticed in your debug log that you are running Wheezy, which is an old Raspbian version no longer supported by Pi-Hole.
You need to be on Raspbian Jessie or Stretch (Stretch is recommended).
https://docs.pi-hole.net/main/prerequesites/
OK, not sure how I got on the dev branch. I was just running pihole -up, and that was the version it was pulling.
So I ran the command. It completed. I reran pihole -up, still get the same error as before. FTL shows offline. So I tried
service pihole-FTL restart
But I get the following error
dnsmasq: failed to create listening socket for port 53: Address already in use
Notice: Found no readable FTL config file
So not sure what to try next.
P.S. And I set this pi up probably 3+ years ago, so not surprising I am on an older version
jfb
March 17, 2019, 5:18pm
4
I think your success path is to change the OS on the Pi to Stretch, then reinstall Pi-Hole with the curl command. It doesn't look like you have much other software running on the Pi.
OK, thanks. I guess I should have not tried to upgrade pihole, just left it well enough alone.
jfb
March 17, 2019, 5:33pm
6
Sooner or later it would have failed, with the combination of an unsupported OS and an older version of FTL.
system
Closed
April 7, 2019, 5:33pm
7
