Pihole + Unbound not blocking ads
Pi-hole + Unbound seems to run normal but is not blocking ads on any device.
Pi-hole is the DHCP server and IPv6 is currently disabled on the router.
Problem appeared after upgrading to a new Router provided by the ISP, however the firmware on it appears to be exactly the same.
https://tricorder.pi-hole.net/gukVgfRs/
From a client what do you see if you run nslookup flurry.com and nslookup pi-hole.net ?
Macbook-Pro ~ % nslookup flurry.com
Server: 192.168.2.102
Address: 192.168.2.102#53
Non-authoritative answer:
Address: 76.223.84.192
Address: 13.248.158.7
Macbook-Pro ~ % nslookup pi-hole.net
Address: 3.18.136.52
I'm assuming that 192.168.2.102 is the pihole? If so then flurry.com should have returned 0.0.0.0 which confirms what your seeing.
192.168.2.102 is the pihole indeed. Tested on windows device in case of private relay and got same response.
Pi-hole is working, but you disabled the Default Group (enabled=0 means disabled):
** [ DIAGNOSING ]: Groups
   id    enabled  name                                                date_added           date_modified        description
   0        0     Default                                             2024-09-28 17:10:24  2025-01-06 19:59:44  The default group
Since you only have one group with one list and this group is disabled, Pi-hole is not blocking.
Enable the Default group and it will start to block.
Thank you!!! Overthinking is real :slight_smile:
