Running PiHole v6 2025.04.0
. and Unbound klutchell/unbound:v1.22.0
and seeing some weird issues. All the issues noted below go away if I switch to my router or CF as upstream resolver. Edit: to add this is the first time I am using Unbound so cannot compare if this was any different in v5.
- Multiple times a day on my browser I will get an error saying unable to reach dns. On refresh it will work. I have tried disabling/enabling secure dns option in browsers and it has no impact. This is seen on multiple different devices and browsers.
- Browser some times feels slower as compared to my router or CF being upstream resolvers.
- Had this issue when a specific dns query would return no data from unbound and then I restarted it and it returned results. I assume this is cache related? The default for
cache-max-ttl
is 1d so I assume it would have fixed itself in a day?
I am using unbound conf mentioned on unbound - Pi-hole documentation. I am using docker networking to talk to unbound on the same host and also add IP address of unbound running on a 2nd host.
pihole:
container_name: pihole
domainname: hole
hostname: pi
image: ghcr.io/pi-hole/pihole:2025.04.0
networks:
default:
ipv4_address: $PIHOLE_IP
ports:
- 53:53/tcp
- 53:53/udp
- 9080:80
volumes:
- ${BASE_DOCKER_DATA_PATH}/pihole/conf:/etc/pihole
environment:
TZ: $TZ
FTLCONF_webserver_api_password: $PIHOLE_PWD
#FTLCONF_dns_upstreams: unbound;$PIHOLE2_IP#5353
#FTLCONF_dns_upstreams: 1.1.1.1;1.0.0.1
FTLCONF_dns_upstreams: 192.168.1.1
FTLCONF_dns_dnssec: 'true'
FTLCONF_dns_domainNeeded: 'True'
FTLCONF_dns_bogusPriv: 'True'
FTLCONF_dns_listeningMode: 'all'
FTLCONF_ntp_ipv4_active: 'False'
FTLCONF_ntp_ipv6_active: 'False'
# https://pi-hole.net/blog/2025/02/21/v6-post-release-fixes-and-findings/#page-content
# no-0x20-encode to help with intermittent issue with cloudflared
# https://discourse.pi-hole.net/t/dnsmasq-warn-reducing-dns-packet-size/51803/30
FTLCONF_misc_dnsmasq_lines: 'no-0x20-encode;address=/xxx.yyyy/192.168.1.86;rebind-domain-ok=/plex.direct/'
FTLCONF_database_maxDBdays: 7
restart: unless-stopped
unbound:
container_name: unbound
image: klutchell/unbound:v1.22.0
ports:
- 5353:53/udp
- 5353:53/tcp
healthcheck:
# Use the drill wrapper binary to reduce the exit codes to 0 or 1 for healthchecks
test: ['CMD', 'drill-hc', '@127.0.0.1', 'dnssec.works']
interval: 30s
timeout: 30s
retries: 3
start_period: 30s
volumes:
- ../../data/unbound:/etc/unbound/custom.conf.d
# https://github.com/MatthewVance/unbound-docker-rpi/issues/4#issuecomment-1341653963
cap_add:
- NET_ADMIN
My unbound config is
server:
# logfile: "/var/log/unbound/unbound.log"
log-time-ascii: yes
verbosity: 1
interface: 127.0.0.1
port: 53
do-ip4: yes
do-udp: yes
do-tcp: yes
# May be set to no if you don't have IPv6 connectivity
do-ip6: yes
prefer-ip6: no
# If you use the default dns-root-data package, unbound will find it automatically
#root-hints: "/var/lib/unbound/root.hints"
# Trust glue only if it is within the server's authority
harden-glue: yes
harden-dnssec-stripped: yes
use-caps-for-id: no
# IP fragmentation is unreliable on the Internet today, and can cause
# transmission failures when large DNS messages are sent via UDP. Even
# when fragmentation does work, it may not be secure; it is theoretically
# possible to spoof parts of a fragmented DNS message, without easy
# detection at the receiving end. Recently, there was an excellent study
# >>> Defragmenting DNS - Determining the optimal maximum UDP response size for DNS <<<
# by Axel Koolhaas, and Tjeerd Slokker (https://indico.dns-oarc.net/event/36/contributions/776/)
# in collaboration with NLnet Labs explored DNS using real world data from the
# the RIPE Atlas probes and the researchers suggested different values for
# IPv4 and IPv6 and in different scenarios. They advise that servers should
# be configured to limit DNS messages sent over UDP to a size that will not
# trigger fragmentation on typical network links. DNS servers can switch
# from UDP to TCP when a DNS response is too big to fit in this limited
# buffer size. This value has also been suggested in DNS Flag Day 2020.
edns-buffer-size: 1232
prefetch: yes
# One thread should be sufficient, can be increased on beefy machines. In reality for most users running on small networks or on a single machine, it should be unnecessary to seek performance enhancement by increasing num-threads above 1.
num-threads: 1
so-rcvbuf: 1m
private-address: 10.0.0.0/8
private-address: fd00::/8
private-address: fe80::/10
private-domain: plex.direct
I am not able to determine why would see the issue #1 i see with unbound and not with any other upstream dns. Any pointers on what I should look at?
