I have been using Pi Hole on Raspberry Pi Zero for some time and tried to install unbound.
I have installed and configured as per the official guide (https://docs.pi-hole.net/guides/dns/unbound/).
I have done these checks and everything looks ok:
unbound.service - Unbound DNS server
Active: active (running) since Thu 2021-04-29 17:37:10 CEST; 2h 44min ago
Docs: man:unbound(8)
Process: 354 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 371 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Main PID: 395 (unbound)
CGroup: /system.slice/unbound.service
└─395 /usr/sbin/unbound -d
apr 29 17:37:06 raspberrypi systemd[1]: Starting Unbound DNS server...
apr 29 17:37:09 raspberrypi package-helper[371]: /var/lib/unbound/root.key has content
apr 29 17:37:09 raspberrypi package-helper[371]: fail: the anchor is NOT ok and could not be fixed
apr 29 17:37:10 raspberrypi systemd[1]: Started Unbound DNS server.
apr 29 17:37:10 raspberrypi unbound[395]: [395:0] info: start of service (unbound 1.9.0).
But If I check 1.1.1.1/help, my ISP shows up.
It's normal?
Am I doing something wrong?
Debug Information
Connected to 1.1.1.1 No
Using DNS over HTTPS (DoH) No
Using DNS over TLS (DoT) No
Using DNS over WARP No
AS Name My ISP
I'm not sure everything is working. How can I check the dns?
Thank you!
