resolve through unbound
and/or
if unbound is disabled and dns is google and quad9. i still should be about to use apt update
i can ping, nslookup and dig raspbian.raspberrypi.org successfully, but apt will not work with or without unbound and settings restarted.
so the main problem is i can not resolve certain websites. ie xboxlive. I can see it resolve in the logs but still does not reach the device. Unbound has been working for weeks and then magicly doesnt. After disabling unbound and setting nameservers to google and quad9, restarted dhcpd, pihole-ftl still can not resolve specific services via other devices. yet i can go to website on my laptop.
I have research forums and have tried everyone's advice and no dice.
Err:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out
Err:2 http://archive.raspberrypi.org/debian buster InRelease
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:88:26::2:1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:88:26::1:1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:88:26::1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:80:56::3:1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:84:1e0::2). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:82:47::2:1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:80:56::1:1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:84:1e0::1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:84:1e0::3). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:82:47::1:1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:82:47::1). - connect (101: Network is unreachable)
Cannot initiate the connection to archive.raspberrypi.org:80 (2a00:1098:80:56::2:1). - connect (101: Network is unreachable)
Could not connect to archive.raspberrypi.org:80 (93.93.135.118), connection timed out
Could not connect to archive.raspberrypi.org:80 (93.93.130.212), connection timed out
Could not connect to archive.raspberrypi.org:80 (176.126.240.84), connection timed out
Could not connect to archive.raspberrypi.org:80 (46.235.227.39), connection timed out
Could not connect to archive.raspberrypi.org:80 (93.93.135.141), connection timed out
Could not connect to archive.raspberrypi.org:80 (46.235.231.145), connection timed out
Could not connect to archive.raspberrypi.org:80 (176.126.240.167), connection timed out
Could not connect to archive.raspberrypi.org:80 (46.235.230.122), connection timed out
Could not connect to archive.raspberrypi.org:80 (46.235.231.151), connection timed out
Could not connect to archive.raspberrypi.org:80 (176.126.240.86), connection timed out
Could not connect to archive.raspberrypi.org:80 (93.93.135.117), connection timed out
Could not connect to archive.raspberrypi.org:80 (46.235.231.111), connection timed out
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/buster/InRelease
W: Some index files failed to download. They have been ignored, or old ones used instead.
These are OS level connectivity issues, and not a failure of Pi-hole.
The domains are being resolved (which is what Pi-hole does), but the device cannot complete the connection. That indicates a connectivity problem at the OS level.
dont know what it was but just reformatted and got a fresh pi with pihole installed and everything works but prime video and xbox live. even with pihole disabled. Services look to up as well. im baffled.
This points to an issue outside of Pi-hole. If Pi-hole is disabled, it is blocking nothing. If the content won't load when nothing is being blocked, the problem lies elsewhere.
