The issue I am facing:
I want to be sure that DHCP is completely disabled for the second interface (eth1), so there is no chance that serves ip on that second interface.
Details about my system:
Pihole VM, serving two networks:
192.168.0.0/23 - dhcp and dns
192.168.100.0/23 - only dns
So far, I just enabled the VM so it loads both interfaces. So far is working as expected but from time to time I'm getting this message:
Jun 22 20:48:01 dnsmasq-dhcp[2014]: no address range available for DHCP request via eth1
So I want 100% sure that through eth1 never hands out ip, because I have another dhcp server there. But it keeps serving dns as it has been doing so far.
As you probably are aware of, Pi-hole's embedded DHCP and DNS server pihole-FTL is an extended tailored version of dnsmasq.
As such, pihole-FTL can be configured in the same way as dnsmasq - as long as your configuration settings won't conflict with Pi-hole's own ones.
You can refer to dnsmasq's documentation for available configuration options as usual, while additional settings specific for pihole-FTL can be configured via pihole-FTL.conf.
In your case, you could create a custom configuration file (e.g. /etc/dnsmasq.d/42-dhcp-extras.conf) with the no-dhcp-interface option:
# exclude eth1 from processing DHCP requests
no-dhcp-interface=eth1
Quoting dnsmasq docs:
-2, --no-dhcp-interface=<interface name>
Do not provide DHCP or TFTP on the specified interface, but do provide DNS service.
You probably should resist the obvious choice of configuring eth1 for DNS services in the same configuration file via an additional interface option:
That will cause aforementioned conflicts with some of Pi-hole's own configuration options as exposed via its Interface settings and may result in unexpected or unwanted behaviour when switching options via Pi-hole's UI.
When done adding options, run a dnsmasq syntax check:
pihole-FTL dnsmasq-test
If ok, restart Pi-hole for the settings to take effect:
DNSMASQ_CONFIG FTL failed to start due to cannot read /etc/dnsmasq.d/42-dhcp-extras.conf.save: Permission denied
I had to delete the /etc/dnsmasq.d/42-dhcp-extras.conf file plus another file called 42-dhcp-extras.conf.save.1 which I supposed dnsmasq made (I was without pihole for like 5min trying to understand what happened XD )
But yeah, apparently for some unknown reason, the main file I made could not be read and when I tried to delete it, it would try to recreate it.
What did I do wrong? I mean, is quite a vanilla Debian 11 VM with just pihole.
For context:
root@Pi-Hole:/home/master# nano /etc/dnsmasq.d/42-dhcp-extras.conf
root@Pi-Hole:/home/master# pihole-FTL dnsmasq-test
dnsmasq: syntax check OK.
root@Pi-Hole:/home/master# pihole restartdns
[✗] /usr/local/bin/pihole: line 163: service: command not found
root@Pi-Hole:/home/master# su pihole restartdns
This account is currently not available.
root@Pi-Hole:/home/master# sudo pihole restartdns
[✓] Restarting DNS server
root@Pi-Hole:/home/master# rm /etc/dnsmasq.d/42-dhcp-extras.conf
root@Pi-Hole:/home/master# rm /etc/dnsmasq.d/42-dhcp-extras.conf.save
root@Pi-Hole:/home/master# ls /etc/dnsmasq.d/
01-pihole.conf 02-pihole-dhcp.conf 04-pihole-static-dhcp.conf 06-rfc6761.conf 42-access-point.conf 42-dhcp-extras.conf.save.1
root@Pi-Hole:/home/master# rm 42-dhcp-extras.conf.save.1
rm: cannot remove '42-dhcp-extras.conf.save.1': No such file or directory
root@Pi-Hole:/home/master# rm /etc/dnsmasq.d/42-dhcp-extras.conf.save.1
The save.1 suffix would suggest some kind of backup, maybe created by your editor. dnsmasq just reads configuration files - it wouldn't create them, and neither would Pi-hole do so for custom conf file, just for its own ones.
Both of your 42-dhcp-extras.conf as well as your 42-access-point.conf are custom configurations, so they won't be created nor recreated by Pi-hole.
