Objective: Configure local DNS records through a configuration file.
It is absolutely unacceptable to configure local DNS records through the Web UI.
It is absolutely unacceptable to configure local DNS records through the pihole CLI.
I should be able to edit the configuration option [dns]::hosts in file /etc/pihole/pihole.toml and have my changes take place after systemctl restart pihole-FTL.
These instructions come from the /etc/pihole/hosts/custom.list
root@vox:/etc/pihole/hosts# head -n 23 custom.list
# (c) 2026 Pi-hole, LLC (https://pi-hole.net)
# Custom DNS entries (HOSTS file)
# FILE AUTOMATICALLY POPULATED BY PI-HOLE #
# ANY CHANGES MADE TO THIS FILE WILL BE LOST WHEN THE CONFIGURATION CHANGES #
# IF YOU WISH TO CHANGE ANY OF THESE VALUES, CHANGE THEM IN #
# /etc/pihole/pihole.toml #
# and restart pihole-FTL #
# ANY OTHER CHANGES SHOULD BE MADE IN A SEPARATE CONFIG FILE #
# WITHIN /etc/dnsmasq.d/yourname.conf #
# (make sure misc.etc_dnsmasq_d is set to true in /etc/pihole/pihole.toml) #
# Last updated: 2026-03-13 14:59:53 CDT #
# by FTL version v6.5 #
Operating System: Raspberry Pi Lite (Debian Trixie 13)
Hardware: Raspberry Pi 5 1GB
Docker compose file or Docker run command: N/A
Docker engine version: N/A
Nothing happens. As soon as I edit the file, FTL immediately overwrites the file with whatever was presently in there. systemctl stop pihole-FTL followed by editing and systemctl start pihole-FTLimmediately overwrites /etc/pihole/pihole.toml with what’s currently in there.
printenv on the root account shows no environment variables starting with FTLCONF
Yes, I am certain I have formatted my toml correctly.
Some further experimental results
PiHole’s TOML parser will strip blank lines, comments, and trailing commas from the [dns]hosts setting, even if the TOML is correctly formatted.
If I paste invalid TOML into [dns]hosts pihole will reload the last-known good [dns]hosts setting
The issue was that I was pasting in comments and blank space and they’d all just disappear, making it look like I’d made 0 progress.
I’m surprised by how invalid TOML is handled. Is there a setting somewhere I can flip which makes everything crash and burn instead of reloading last known good?
I'm reasonably certain that this is not a good idea, but it is possible to prevent pihole overwriting your bespoke toml file.
Edits will need to be made, and the file set to immutable while the pihole-FTL service stopped. Once you are done editing, make the toml file immutable using chattr and then Pi-hole won't be able to delete, rewrite or overwrite it.
sudo chattr +i /etc/pihole/pihole.toml
Then restart the pihole-FTL service.
So long as the file is parseable, pihole will read the file and use it but won't overwrite your file. You will see a warning in FTL.log:
WARNING: Cannot move temporary config file to final location (Operation not permitted), content not updated.
If the file is not parseable, pihole will use its last known good config, but leave the mangled file alone:
ERROR: Cannot parse config file: (line 15) invalid value
ERROR: Cannot parse TOML file: (line 15) invalid value
INFO: Using config backup /etc/pihole/config_backups/pihole.toml.1
If you later wanted to change the file yourself, you would need to first remove the immutability flag:
Pi-hole will always rewrite pihole.toml using only its own comments, which are part of the documentation.
Also, I don't know what will happen if you try to make the file immutable. This is not recommended.
If you really want to keep your comments, the only suggestion I have is: create your own pihole.toml file (with your settings and comments) and save it on your home directory.
Since you will never use the web interface or the CLI commands to change your settings, this file will contain all Pi-hole settings.
When you need to change something, you can edit this file and them copy it to /etc/pihole/.
Do you have a link I can follow? Maybe there are hidden developer docs somewhere I haven’t found and I would have wanted to read those before making the post.
I didn’t see anything specifically in pihole.toml's comments
I couldn’t find a reference to this on docs.pi-hole.net: Almost all my information comes from the Docker > Configuration page, and the Advanced > Signals page seems to support the idea that pihole only reads from pihole.toml instead of overwriting it
I also didn’t see anything in a brief search of the github repo, and I didn’t have enough time to actually read through the code.
Since I like to manage everything from one place where possible, I think I’ll utilize the /home/username/pihole.toml approach. I’ll always have the ability to diff my personal config and the live config – I just need to keep those autoformat rules in mind.
Link for what exactly? I'm not sure what you want to see.
If you don't believe me when I say the file is recreated, you can easily test yourself.
Create a backup copy of your pihole.toml and then delete the original file. You will see that the file is really gone.
Pi-hole will keep working without the file until you execute any operation that restarts the DNS resolver, like changing a config option via CLI or the web interface. You can test that executing sudo pihole-FTL --config webserver.api.sessions 16.
After that, the file pihole.toml will be back, because it was recreated by FTL.
EDIT:
I think I found what you are looking for.
This is a comment that explains pihole.toml is always rewritten after FTL parsing it:
