Hello, I wanna route my pihole dns records that sit on one subnet ie 192.168.. through to my subnets of ip 10.84.. that are run on pfsense so i can use my local dns records via pfsense and my isp router without having to change machine. Is this possible.
I guess you are asking whether Pi-hole can be used as the sole DNS server for all your subnets, while it retrieves certain local DNS records as defined in pfsense?
If so, the latter can be achieved by enabling Pi-hole's Conditional Forwarding, while the former is primarily a a question about your router allowing you to configure cross-subnet / inter-VLAN traffic.
If that is not your question, please try to rephrase it, probably by also providing an example of your aspired DNS lookup behaviour.
So basically my pi hole and pf sense (wan) sit on 192.168.-.- and my dns A record for pihole is pointing to my machine that runs traefik via pfsense (lan) eg ip: 10.62.-.- and I’d like to use the local dns records on that lan subnet via my wan ip and also my lan ip.
Are u able to help
Hello can anyone help
