Access to websites through DNS resolution. Running Debian 12, Pi-hole v5.18.2, FTL v5.25.1, FritzBox 7590
The PiHole cannot resolve any dns requests from clients or itself. I have tried pihole -r and it fails (Status: Connection Refused) .
After reinstalling it works but only for an Hour after that only my PC continues to Work
I can access the web gui ,ssh into the pihole and ping/dig external services.
resolv.conf points to itself. Changing the Nameserver won't work either
I really don't know anymore.
Tools > Generate Debug Log
If this will not upload the log, then
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
Edit the nameserver line to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Changing resolv.conf does unfortunately not work for the Debug command.
Using dig it shows that it changed the DNS but the pihole does not acknowledge it.
I tried resetting the Pihole and it works for about an Hour until it doesn't.
