Pihole shows zero activity
Hi guys,
I installed Pihole the other on my raspberry Pi2 with latest version of Raspbian.
Once all the installation was done ruining through I changed the password and successfully managed to login.
I than expected to see some statistical numbers of how bad hosts Pihole would know from it's databases.
However I expected as from previous installations to see a lot statistical figures on the page inside my browser.
Strangely there no numbers at all. I also tried to generate some figures by changing the DNS setting to the IP address of the Pi2. Still no stats at all.
Can you please advise me on how to resolve this issue ?
Thx, user 4747
May I ask.
Do you run Windows?
Do you use AVAST antivirus?
https://discourse.pi-hole.net/t/thanks-for-nothing-microsoft/5226/11
Yes I do use Windows 7
And I do use Avast.
And I just temporary disabled Avast and can not belive that Pihole is now working fine.
Thx, for the help
Try this fix by @marcdraco63
I would not disable you AV for too long.
https://discourse.pi-hole.net/t/thanks-for-nothing-microsoft/5226/12
https://www.facebook.com/groups/BIRRR/permalink/754926484716041/
Yeah - don't disable the whole thing - AVAST isn't doing this out of badness, it's a case of of two helpful programs working against each other. You can remove or disable the component and you'll be good to go!
I have filed a bug report with the company so hopefully we'll be able to use both soon.
