Hello, i just installed pi-hole and its showing 0 clients, i set static ip and all but idk whats wrong.
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2024-01-28:14:52:29 debug log has been initialized.
[i] System has been running for 0 days, 0 hours, 24 minutes
[✓] Version: v5.17.3
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.17.3-0-g19bfa08
[✓] Version: v5.21
[i] Remotes: origin https://github.com/pi-hole/web.git (fetch)
origin https://github.com/pi-hole/web.git (push)
[i] Branch: master
[i] Commit: v5.21-0-gbe05b0f
[✓] Version: v5.24
[i] Branch: master
[i] Commit: 01227311
[i] 1.4.63
[i] 8.1.2
[✗] Distro: Linuxmint
[✓] dig return code: 0
[i] dig response: "Raspbian=10,11,12 Ubuntu=20,22,23 Debian=10,11,12 Fedora=36,37,38 CentOS=8,9"
[✗] Error: Linuxmint is not a supported distro (https://docs.pi-hole.net/main/prerequisites/)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[i] Firewalld service inactive
*** [ DIAGNOSING ]: Processor
[✓] x86_64
*** [ DIAGNOSING ]: Disk usage
Filesystem Size Used Avail Use% Mounted on
tmpfs 1,3G 1,8M 1,3G 1% /run
/dev/nvme0n1p2 468G 48G 397G 11% /
tmpfs 6,3G 748K 6,3G 1% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
/dev/nvme0n1p1 511M 6,1M 505M 2% /boot/efi
tmpfs 1,3G 7,0M 1,3G 1% /run/user/1000
*** [ DIAGNOSING ]: Network interfaces and addresses
inet6 ::1/128 scope host
2: enp1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether b0:41:6f:0e:88:c1 brd ff:ff:ff:ff:ff:ff
3: wlo1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 70:d8:c2:14:69:cd brd ff:ff:ff:ff:ff:ff
altname wlp2s0
inet 192.168.212.4/24 brd 192.168.212.255 scope global noprefixroute wlo1
inet6 fe80::a7b7:f124:bf7f:9ed0/64 scope link noprefixroute
*** [ DIAGNOSING ]: Network routing table
default via 192.168.212.1 dev wlo1 proto static metric 600
169.254.0.0/16 dev wlo1 scope link metric 1000
192.168.212.0/24 dev wlo1 proto kernel scope link src 192.168.212.4 metric 600
[✗] No IPv4 address(es) found on the enp1s0 interface.
[✗] No IPv6 address(es) found on the enp1s0 interface.
[i] Default IPv4 gateway(s):
[i] Default IPv6 gateway(s):
udp:0.0.0.0:59445 is in use by avahi-daemon
udp:192.168.212.4:59705 is in use by webcord
udp:224.0.0.251:5353 is in use by webcord
udp:0.0.0.0:5353 is in use by avahi-daemon
[✓] udp:0.0.0.0:53 is in use by pihole-FTL
udp:0.0.0.0:631 is in use by cups-browsed
udp:[::]:5353 is in use by avahi-daemon
[✓] udp:[::]:53 is in use by pihole-FTL
udp:[::]:41414 is in use by avahi-daemon
udp:[fe80::a7b7:f124:bf7f:9ed0]%wlo1:546 is in use by NetworkManager
[✓] tcp:0.0.0.0:53 is in use by pihole-FTL
tcp:127.0.0.1:631 is in use by cupsd
tcp:127.0.0.1:6463 is in use by webcord
[✓] tcp:127.0.0.1:4711 is in use by pihole-FTL
[✓] tcp:0.0.0.0:80 is in use by lighttpd
[✓] tcp:[::]:53 is in use by pihole-FTL
tcp:[::1]:631 is in use by cupsd
[✓] tcp:[::1]:4711 is in use by pihole-FTL
[✓] tcp:[::]:80 is in use by lighttpd
[✓] merelys-xyz.preview-domain.com is 0.0.0.0 on lo (127.0.0.1)
[✓] No IPv4 address available on enp1s0
[✓] merelys-xyz.preview-domain.com is 0.0.0.0 on wlo1 (192.168.212.4)
[✓] doubleclick.com is 142.250.186.174 via a remote, public DNS server (8.8.8.8)
[✓] destinycenterbakersfield.com is :: on lo (::1)
[✓] No IPv6 address available on enp1s0
[✗] Failed to resolve destinycenterbakersfield.com on wlo1 (fe80::a7b7:f124:bf7f:9ed0)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
Timeout: 10 seconds
* Received 300 bytes from wlo1:192.168.212.1
Offered IP address: 192.168.212.143
Server IP address: 192.168.212.1
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 192.168.212.1
lease-time: 43200 ( 12h )
renewal-time: 21600 ( 6h )
rebinding-time: 37800 ( 10h 30m )
netmask: 255.255.255.0
broadcast: 192.168.212.255
router: 192.168.212.1
dns-server: 192.168.212.1
wpad-server: "(empty)"
--- end of options ---
DHCP packets received on interface wlo1: 1
[✓] lighttpd daemon is active
*** [ DIAGNOSING ]: Pi-hole-FTL full status
● pihole-FTL.service - Pi-hole FTL
Loaded: loaded (/etc/systemd/system/pihole-FTL.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2024-01-28 14:34:39 EET; 18min ago
Process: 5241 ExecStartPre=/opt/pihole/pihole-FTL-prestart.sh (code=exited, status=0/SUCCESS)
Main PID: 5254 (pihole-FTL)
Tasks: 19 (limit: 15306)
Memory: 3.8M
CPU: 578ms
└─5254 /usr/bin/pihole-FTL -f
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.325 5254M] PIHOLE_PTR: internal PTR generation enabled (pi.hole)
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.325 5254M] ADDR2LINE: Enabled
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.325 5254M] REPLY_WHEN_BUSY: Drop queries when the database is busy
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.325 5254M] BLOCK_TTL: 2 seconds
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.325 5254M] BLOCK_ICLOUD_PR: Enabled
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.325 5254M] CHECK_LOAD: Enabled
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.325 5254M] CHECK_SHMEM: Warning if shared-memory usage exceeds 90%
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.326 5254M] CHECK_DISK: Warning if certain disk usage exceeds 90%
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.326 5254M] Finished config file parsing
Jan 28 14:34:39 evangelosan-SER pihole-FTL[5254]: [2024-01-28 14:34:39.326 5254M] Creat
*** [ DIAGNOSING ]: Lighttpd configuration test
[✓] No error in lighttpd configuration
PIHOLE_INTERFACE=enp1s0
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
CACHE_SIZE=10000
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSMASQ_LISTENING=local
BLOCKING_ENABLED=true
PIHOLE_DNS_1=1.1.1.1
PIHOLE_DNS_2=1.0.0.1
PIHOLE_DNS_3=2606:4700:4700::1111
PIHOLE_DNS_4=2606:4700:4700::1001
DNSSEC=false
REV_SERVER=false
*** [ DIAGNOSING ]: Dashboard headers
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Pi-hole FTL Query Database
-rw-rw-r-- 1 pihole pihole 80K Jan 28 14:52 /etc/pihole/pihole-FTL.db
*** [ DIAGNOSING ]: Gravity Database
-rw-rw-r-- 1 pihole pihole 9,2M Jan 28 14:37 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 15
updated 1706444534
gravity_count 157538
Last gravity run finished at: Sun Jan 28 02:22:14 PM EET 2024
----- First 10 Gravity Domains -----
localhost.localdomain
ck.getcookiestxt.com
eu1.clevertap-prod.com
wizhumpgyros.com
coccyxwickimp.com
webmail-who-int.000webhostapp.com
010sec.com
01mspmd5yalky8.com
0byv9mgbn0.com
ns6.0pendns.org
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2024-01-28 14:22:13 2024-01-28 14:22:13 The default group
*** [ DIAGNOSING ]: Clients
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2024-01-28 14:22:13 2024-01-28 14:22:13 Migrated from /etc/pihole/adlists.list
-rw-r--r-- 1 root root 0 Jan 28 14:22 /etc/pihole/custom.list
-rw-r--r-- 1 root root 65 Jan 28 14:22 /etc/pihole/local.list
-rw-r--r-- 1 root root 245 Jan 28 14:22 /etc/pihole/logrotate
/var/log/pihole/pihole.log {
su root syslog
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole/FTL.log {
su root syslog
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 146 Jan 28 14:34 /etc/pihole/pihole-FTL.conf
PRIVACYLEVEL=0
RATE_LIMIT=1000/60
-rw-r--r-- 1 root root 321 Jan 28 14:28 /etc/pihole/versions
CORE_VERSION=v5.17.3
CORE_BRANCH=master
CORE_HASH=19bfa08b
GITHUB_CORE_VERSION=v5.17.3
GITHUB_CORE_HASH=19bfa08b
WEB_VERSION=v5.21
WEB_BRANCH=master
WEB_HASH=be05b0f6
GITHUB_WEB_VERSION=v5.21
GITHUB_WEB_HASH=be05b0f6
FTL_VERSION=v5.24
FTL_BRANCH=master
FTL_HASH=01227311
GITHUB_FTL_VERSION=v5.24
GITHUB_FTL_HASH=01227311
-rw-r--r-- 1 root root 1,5K Jan 28 14:34 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
log-queries
log-facility=/var/log/pihole/pihole.log
log-async
cache-size=10000
server=1.1.1.1
server=1.0.0.1
server=2606:4700:4700::1111
server=2606:4700:4700::1001
domain-needed
expand-hosts
bogus-priv
local-service
-rw-r--r-- 1 root root 2,2K Jan 28 14:22 /etc/dnsmasq.d/06-rfc6761.conf
server=/test/
server=/localhost/
server=/invalid/
server=/bind/
server=/onion/
-rw-r--r-- 1 root root 2,2K Dec 30 2021 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_indexfile",
"mod_access",
"mod_alias",
"mod_redirect",
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
server.feature-flags += ("server.h2proto" => "enable")
server.feature-flags += ("server.h2c" => "enable")
server.feature-flags += ("server.graceful-shutdown-timeout" => 5)
server.http-parseopts = (
"header-strict" => "enable",# default
"host-strict" => "enable",# default
"host-normalize" => "enable",# default
"url-normalize-unreserved"=> "enable",# recommended highly
"url-normalize-required" => "enable",# recommended
"url-ctrls-reject" => "enable",# recommended
"url-path-2f-decode" => "enable",# recommended highly (unless breaks app)
"url-path-dotseg-remove" => "enable",# recommended highly (unless breaks app)
index-file.names = ( "index.php", "index.html" )
url.access-deny = ( "~", ".inc" )
include_shell "/usr/share/lighttpd/create-mime.conf.pl"
include "/etc/lighttpd/conf-enabled/*.conf"
server.modules += (
"mod_dirlisting",
"mod_staticfile",
*** [ DIAGNOSING ]: contents of /etc/lighttpd/conf.d
/etc/lighttpd/conf.d does not exist.
*** [ DIAGNOSING ]: contents of /etc/lighttpd/conf-enabled
total 0
lrwxrwxrwx 1 root root 32 Jan 28 14:22 05-setenv.conf -> ../conf-available/05-setenv.conf
lrwxrwxrwx 1 root root 35 Jan 28 14:22 10-accesslog.conf -> ../conf-available/10-accesslog.conf
lrwxrwxrwx 1 root root 33 Jan 28 14:22 10-fastcgi.conf -> ../conf-available/10-fastcgi.conf
lrwxrwxrwx 1 root root 38 Jan 28 14:22 15-pihole-admin.conf -> ../conf-available/15-pihole-admin.conf
lrwxrwxrwx 1 root root 38 Jan 28 14:21 99-unconfigured.conf -> ../conf-available/99-unconfigured.conf
lrwxrwxrwx 1 root root 38 Jan 28 14:22 /etc/lighttpd/conf-enabled/15-pihole-admin.conf -> ../conf-available/15-pihole-admin.conf
server.errorlog := "/var/log/lighttpd/error-pihole.log"
$HTTP["url"] =~ "^/admin/" {
server.stream-response-body = 1
accesslog.filename = "/var/log/lighttpd/access-pihole.log"
accesslog.format = "%{%s}t|%h|%V|%r|%s|%b"
fastcgi.server = (
".php" => (
"localhost" => (
"socket" => "/run/lighttpd/pihole-php-fastcgi.socket",
"bin-path" => "/usr/bin/php-cgi",
"min-procs" => 1,
"max-procs" => 1,
"bin-environment" => (
"PHP_FCGI_CHILDREN" => "4",
"PHP_FCGI_MAX_REQUESTS" => "10000",
"bin-copy-environment" => (
"PATH", "SHELL", "USER"
"broken-scriptfilename" => "enable",
"X-Frame-Options" => "DENY",
"X-XSS-Protection" => "0",
"X-Content-Type-Options" => "nosniff",
"Content-Security-Policy" => "default-src 'self' 'unsafe-inline';",
"X-Permitted-Cross-Domain-Policies" => "none",
"Referrer-Policy" => "same-origin"
$HTTP["url"] =~ "^/admin/\." {
url.access-deny = ("")
$HTTP["url"] =~ "/(teleporter|api_token)\.php$" {
$HTTP["referer"] =~ "/admin/settings\.php" {
setenv.set-response-header = ( "X-Frame-Options" => "SAMEORIGIN" )
else $HTTP["url"] == "/admin" {
url.redirect = ("" => "/admin/")
$HTTP["host"] == "pi.hole" {
$HTTP["url"] == "/" {
server.modules += ( "mod_access", "mod_accesslog", "mod_redirect", "mod_fastcgi", "mod_setenv" )
-rw-r--r-- 1 root root 1,7K Jan 28 14:22 /etc/cron.d/pihole
2 3 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole/pihole_updateGravity.log || cat /var/log/pihole/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
@reboot root /usr/sbin/logrotate --state /var/lib/logrotate/pihole /etc/pihole/logrotate
30 16 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker reboot
-rw-r--r-- 1 www-data www-data 211 Jan 28 14:27 /var/log/lighttpd/error-pihole.log
-----head of error-pihole.log------
2024-01-28 14:22:12: (server.c.1551) server started (lighttpd/1.4.63)
2024-01-28 14:27:19: (server.c.2057) server stopped by UID = 0 PID = 1
2024-01-28 14:27:54: (server.c.1551) server started (lighttpd/1.4.63)
-----tail of error-pihole.log------
*** [ DIAGNOSING ]: contents of /var/log/pihole
-rw-r--r-- 1 pihole pihole 22K Jan 28 14:37 /var/log/pihole/FTL.log
-----head of FTL.log------
[2024-01-28 14:22:13.222 21273M] Using log file /var/log/pihole/FTL.log
[2024-01-28 14:22:13.222 21273M] ########## FTL started on evangelosan-SER! ##########
[2024-01-28 14:22:13.222 21273M] FTL branch: master
[2024-01-28 14:22:13.222 21273M] FTL version: v5.24
[2024-01-28 14:22:13.222 21273M] FTL commit: 01227311
[2024-01-28 14:22:13.222 21273M] FTL date: 2024-01-06 16:47:56 +0000
[2024-01-28 14:22:13.222 21273M] FTL user: pihole
[2024-01-28 14:22:13.222 21273M] Compiled for x86_64 (compiled on CI) using gcc (Debian 8.3.0-6) 8.3.0
[2024-01-28 14:22:13.222 21273M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2024-01-28 14:22:13.222 21273M] SOCKET_LISTENING: only local
[2024-01-28 14:22:13.222 21273M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2024-01-28 14:22:13.222 21273M] MAXDBDAYS: max age for stored queries is 365 days
[2024-01-28 14:22:13.222 21273M] RESOLVE_IPV6: Resolve IPv6 addresses
[2024-01-28 14:22:13.222 21273M] RESOLVE_IPV4: Resolve IPv4 addresses
[2024-01-28 14:22:13.222 21273M] DBINTERVAL: saving to DB file every minute
[2024-01-28 14:22:13.222 21273M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2024-01-28 14:22:13.222 21273M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2024-01-28 14:22:13.222 21273M] PRIVACYLEVEL: Set to 0
[2024-01-28 14:22:13.222 21273M] IGNORE_LOCALHOST: Show queries from localhost
[2024-01-28 14:22:13.222 21273M] BLOCKINGMODE: Null IPs for blocked domains
[2024-01-28 14:22:13.222 21273M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2024-01-28 14:22:13.222 21273M] DBIMPORT: Importing history from database
[2024-01-28 14:22:13.222 21273M] PIDFILE: Using /run/pihole-FTL.pid
[2024-01-28 14:22:13.222 21273M] SOCKETFILE: Using /run/pihole/FTL.sock
[2024-01-28 14:22:13.222 21273M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2024-01-28 14:22:13.222 21273M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2024-01-28 14:22:13.222 21273M] GRAVITYDB: Using /etc/pihole/gravity.db
[2024-01-28 14:22:13.222 21273M] PARSE_ARP_CACHE: Active
[2024-01-28 14:22:13.222 21273M] CNAME_DEEP_INSPECT: Active
[2024-01-28 14:22:13.222 21273M] DELAY_STARTUP: No delay requested.
[2024-01-28 14:22:13.222 21273M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2024-01-28 14:22:13.222 21273M] NICE: Set process niceness to -10 (default)
[2024-01-28 14:22:13.222 21273M] MAXNETAGE: Removing IP addresses and host names from network table after 365 days
[2024-01-28 14:22:13.222 21273M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2024-01-28 14:22:13.222 21273M] EDNS0_ECS: Overwrite client from ECS information
-----tail of FTL.log------
[2024-01-28 14:34:39.326 5254M] Creating mutex
[2024-01-28 14:34:39.326 5254M] PID of FTL process: 5254
[2024-01-28 14:34:39.326 5254M] Database version is 12
[2024-01-28 14:34:39.326 5254M] Resizing "FTL-strings" from 40960 to (81920 * 1) == 81920 (/dev/shm: 725.0KB used, 6.8GB total, FTL uses 700.8KB)
[2024-01-28 14:34:39.326 5254M] Imported 0 alias-clients
[2024-01-28 14:34:39.326 5254M] Database successfully initialized
[2024-01-28 14:34:39.332 5254M] Imported 0 queries from the long-term database
[2024-01-28 14:34:39.332 5254M] -> Total DNS queries: 0
[2024-01-28 14:34:39.332 5254M] -> Cached DNS queries: 0
[2024-01-28 14:34:39.332 5254M] -> Forwarded DNS queries: 0
[2024-01-28 14:34:39.332 5254M] -> Blocked DNS queries: 0
[2024-01-28 14:34:39.333 5254M] -> Unknown DNS queries: 0
[2024-01-28 14:34:39.333 5254M] -> Unique domains: 0
[2024-01-28 14:34:39.333 5254M] -> Unique clients: 0
[2024-01-28 14:34:39.333 5254M] -> Known forward destinations: 0
[2024-01-28 14:34:39.333 5254M] Successfully accessed setupVars.conf
[2024-01-28 14:34:39.333 5254M] listening on 0.0.0.0 port 53
[2024-01-28 14:34:39.333 5254M] listening on :: port 53
[2024-01-28 14:34:39.333 5254M] PID of FTL process: 5254
[2024-01-28 14:34:39.333 5254M] Listening on port 4711 for incoming IPv4 telnet connections
[2024-01-28 14:34:39.333 5254M] Listening on port 4711 for incoming IPv6 telnet connections
[2024-01-28 14:34:39.333 5254M] Listening on port 4711 for incoming socket telnet connections
[2024-01-28 14:34:39.334 5254M] INFO: FTL is running as user pihole (UID 998)
[2024-01-28 14:34:39.334 5254M] Reloading DNS cache
[2024-01-28 14:34:39.434 5254/T5278] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 0.1 msec
[2024-01-28 14:34:39.434 5254/T5278] Blocking status is enabled
[2024-01-28 14:37:08.996 5254M] Received: Real-time signal 0 (34 -> 0)
[2024-01-28 14:37:09.061 5254/T5278] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 0.1 msec
[2024-01-28 14:37:09.061 5254/T5278] Blocking status is enabled
[2024-01-28 14:37:44.221 5254M] Received: Real-time signal 0 (34 -> 0)
[2024-01-28 14:37:44.305 5254/T5278] Compiled 0 whitelist and 0 blacklist regex filters for 0 clients in 0.1 msec
[2024-01-28 14:37:44.305 5254/T5278] Blocking status is enabled
*** [ DIAGNOSING ]: contents of /dev/shm
total 748K
-rw------- 1 pihole pihole 84K Jan 28 14:34 FTL-clients
-rw------- 1 pihole pihole 248 Jan 28 14:34 FTL-counters
-rw------- 1 pihole pihole 4,0K Jan 28 14:34 FTL-dns-cache
-rw------- 1 pihole pihole 12K Jan 28 14:34 FTL-domains
-rw------- 1 pihole pihole 88 Jan 28 14:34 FTL-lock
-rw------- 1 pihole pihole 8,0K Jan 28 14:34 FTL-overTime
-rw------- 1 pihole pihole 4,0K Jan 28 14:34 FTL-per-client-regex
-rw------- 1 pihole pihole 224K Jan 28 14:34 FTL-queries
-rw------- 1 pihole pihole 16 Jan 28 14:34 FTL-settings
-rw------- 1 pihole pihole 80K Jan 28 14:34 FTL-strings
-rw------- 1 pihole pihole 308K Jan 28 14:34 FTL-upstreams
-rw-rw-r-- 1 evangelosan evangelosan 3,9K Jan 28 14:31 xapp-tmp-0x55b0eb6ee220-0.png
-rw-rw-r-- 1 evangelosan evangelosan 4,1K Jan 28 14:31 xapp-tmp-0x55b0eb6ee220-1.png
-rw-r--r-- 1 root root 24 Jan 28 14:22 /etc/dnsmasq.conf
conf-dir=/etc/dnsmasq.d
lrwxrwxrwx 1 root root 39 Jan 27 17:34 /etc/resolv.conf -> ../run/systemd/resolve/stub-resolv.conf
nameserver 1.1.1.1
search .
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
*** [ DIAGNOSING ]: Locale
LANG=en_US.UTF-8
-rw-r----- 1 pihole pihole 4,3K Jan 28 14:52 /var/log/pihole/pihole.log
-----head of pihole.log------
Jan 28 14:22:13 dnsmasq[21273]: started, version pi-hole-v2.89-9461807 cachesize 10000
Jan 28 14:22:13 dnsmasq[21273]: DNS service limited to local subnets
Jan 28 14:22:13 dnsmasq[21273]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
Jan 28 14:22:13 dnsmasq[21273]: using nameserver 1.1.1.1#53
Jan 28 14:22:13 dnsmasq[21273]: using nameserver 1.0.0.1#53
Jan 28 14:22:13 dnsmasq[21273]: using only locally-known addresses for onion
Jan 28 14:22:13 dnsmasq[21273]: using only locally-known addresses for bind
Jan 28 14:22:13 dnsmasq[21273]: using only locally-known addresses for invalid
Jan 28 14:22:13 dnsmasq[21273]: using only locally-known addresses for localhost
Jan 28 14:22:13 dnsmasq[21273]: using only locally-known addresses for test
Jan 28 14:22:13 dnsmasq[21273]: read /etc/hosts - 8 names
Jan 28 14:22:13 dnsmasq[21273]: read /etc/pihole/custom.list - 0 names
Jan 28 14:22:13 dnsmasq[21273]: failed to load names from /etc/pihole/local.list: No such file or directory
Jan 28 14:22:14 dnsmasq[21273]: read /etc/hosts - 8 names
Jan 28 14:22:14 dnsmasq[21273]: read /etc/pihole/custom.list - 0 names
Jan 28 14:22:14 dnsmasq[21273]: read /etc/pihole/local.list - 0 names
Jan 28 14:27:20 dnsmasq[21273]: exiting on receipt of SIGTERM
Jan 28 14:27:54 dnsmasq[2123]: started, version pi-hole-v2.89-9461807 cachesize 10000
Jan 28 14:27:54 dnsmasq[2123]: DNS service limited to local subnets
Jan 28 14:27:54 dnsmasq[2123]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
-----tail of pihole.log------
Jan 28 14:34:39 dnsmasq[5254]: using nameserver 1.1.1.1#53
Jan 28 14:34:39 dnsmasq[5254]: using nameserver 1.0.0.1#53
Jan 28 14:34:39 dnsmasq[5254]: using nameserver 2606:4700:4700::1111#53
Jan 28 14:34:39 dnsmasq[5254]: using nameserver 2606:4700:4700::1001#53
Jan 28 14:34:39 dnsmasq[5254]: using only locally-known addresses for onion
Jan 28 14:34:39 dnsmasq[5254]: using only locally-known addresses for bind
Jan 28 14:34:39 dnsmasq[5254]: using only locally-known addresses for invalid
Jan 28 14:34:39 dnsmasq[5254]: using only locally-known addresses for localhost
Jan 28 14:34:39 dnsmasq[5254]: using only locally-known addresses for test
Jan 28 14:34:39 dnsmasq[5254]: read /etc/hosts - 8 names
Jan 28 14:34:39 dnsmasq[5254]: read /etc/pihole/custom.list - 0 names
Jan 28 14:34:39 dnsmasq[5254]: read /etc/pihole/local.list - 0 names
Jan 28 14:52:30 dnsmasq[5254]: query[A] merelys-xyz.preview-domain.com from 127.0.0.1
Jan 28 14:52:30 dnsmasq[5254]: gravity blocked merelys-xyz.preview-domain.com is 0.0.0.0
Jan 28 14:52:30 dnsmasq[5254]: query[A] merelys-xyz.preview-domain.com from 192.168.212.4
Jan 28 14:52:30 dnsmasq[5254]: query[AAAA] destinycenterbakersfield.com from ::1
Jan 28 14:52:30 dnsmasq[5254]: gravity blocked destinycenterbakersfield.com is ::
Jan 28 14:52:30 dnsmasq[5254]: query[PTR] 4.212.168.192.in-addr.arpa from 127.0.0.1
Jan 28 14:52:30 dnsmasq[5254]: config 4.212.168.192.in-addr.arpa is <PTR>
[✓] ** FINISHED DEBUGGING! **
