Pihole sending excessive DHCP Inform Messages
pihole: 5.17.2
FTL: V5.23
Currently have pihole DHCP Server disabled. Seeing that it is sending excessive DHCP INFORM Packets on the Network. Here is an example of DHCP Packets occurring in a single second. 10.0.0.1 is the pihole box. There have been > 485K messages in the last 24 hours, according to an external log.
|Oct 20 20:32:46|dhcpd|51760|DHCPACK to 10.0.0.1 (dc:a6:32:d9:8f:ec) via igb1|
|Oct 20 20:32:46|dhcpd|51760|DHCPINFORM from 10.0.0.1 via igb1|
How can this behavior be disabled?
If Pi-hole's DHCP is disabled, you should not see any such message.
There may be other software running on your host employing dnsmasq, or at least trying to configure it.
Run from your machine hosting Pi-hole, what's the result of
sudo ss -tulpn sport = 67
Also, please upload a debug log and post just the token URL that is generated after the log is uploaded by running the following command from the Pi-hole host terminal:
Tools > Generate Debug Log
Bucking_Horn
Thank you for your reply. Was able to correct the issue. Fortunately there was not another DHCP Server running, however, there was a misconfiguration on the box running pihole. The setting for the static IP Address was set to "inform ", instead of "static ip_address "
Made configuration change and restarted. No longer seeing the DHCP Inform Messages.
Thank You
