Pihole returning correct IP even though domain is on blocklist
Returning 0.0.0.0
  • Operating System (Family and Version) Raspberry Pi OS Lite trixie
  • Hardware Raspberry Pi 4B
It is returning the correct IP
Don’t see it
You have to generate the debug log, then upload the log when prompted. You will then be presented with a token URL - post that.
The command from the terminal to generate a debug log is:
sudo pihole -d
Also, please identify the domain of interest.
