PiHole reinstall on Ubuntu Server 24.04.2 using Apache2 and php files for web interface
Hello community,
The issue I am facing:
I couldn't update pihole on my ubuntu server anymore with "sudo pihole -up", so I have removed it with "sudo pihole uninstall" and want to do a clean reinstall.
At reinstalling with his commands, I was not asked to install without webserver:
git clone --depth 1 GitHub - pi-hole/pi-hole: A black hole for Internet advertisements Pi-hole
cd "Pi-hole/automated install/"
sudo bash basic-install.sh
At "Installation Complete" it told me that I can view web interface at http://...:8080/admin/
(But access not working because port 8080 is used by Apache2 web server and I tried to switch the port, but I couldn't find any lighttpd config file to change the port for pihole web interface.)
Also there was for the web interface at folder /var/www/html/admin/ no *.php files. Instead I had here *.lp files which I can't open with Apache2.
So I uninstalled pihole again.
Should I firstly remove something else which could make troubles from the old pihole installation?
I already did "sudo pihole uninstall".
And secondly what is the correct was to install pihole with *.php files unter .../html/admin/ for web interface without additional webserver, so that I can use existing Apache2 with virtualhost config, because I'm using Apache2 also for other websites on my ubuntu server.
Details about my system:
Ubuntu Server 24.04.2 TLS (GNU/Linux 6.8.0-1019-raspi aarch64) on Raspberry Pi 5
Apache2 with different websites under /var/www/
PHP8.3.6
certbot (letsencrypt)
Thank you for helping,
Alex
This won't happen.
The new web server is Pi-hole itself (pihole-FTL). Without it, Pi-hole won't work.
Pi-hole v6 web interface is a completely new web interface, written in Lua (PHP is gone). It needs to be executed by pihole-FTL web server (we also removed lighttpd).
Apache can't execute the Lua pages, so you need to use the embedded web server.
You can change the Pi-hole port to any other port you want using:
pihole-FTL --config webserver.port '8880,443s'
Notes:
  • port 8880 is just an example. You can use any port you like.
  • you can configure a secure port (https) adding the s flag to a port. This port can also be changed.
You can't. PHP is not part of Pi-hole v6.
You can still run your services under Apache2, but you will need to use pihole-FTL to execute the new Pi-hole web interface.
Thank for the all the informations.
I have disabled port 81 at Apache2 and config the port for pihole-FTL.
After reboot everything now working perfectly.
