PiHole Randomly Says [✗] DNS resolution is currently unavailable
DNS resolution should be consistent and work every time.
I have two PiHoles running and they both have the same issue:
  • Linux PIHOLE01 5.15.84-v7l+ #1613 SMP Thu Jan 5 12:01:26 GMT 2023 armv7l GNU/Linux on Raspberry Pi B+
  • Linux PIHOLE02 5.15.84-v7l+ #1613 SMP Thu Jan 5 12:01:26 GMT 2023 armv7l GNU/Linux on Raspberry Pi B+
PiHole is randomly not able to resolve DNS queries. When I try to do a gravity update or pinhole update, for example, I will get errors related to not being able to resolve a domain (that exists) or I will see this error:
It will wait and try again and everything works just fine.
I had tried changing the PiHole DNS Servers from Level3 to Google with no luck.
My clients are all having random issues with dns resolution as well. I will issue an nslookup from a client and it will timeout and then immediately reissue it and it will work.
This seems to have just started in the past two or three days with no other network changes.
PIHOLE01: https://tricorder.pi-hole.net/CL5WIoXk/
PIHOLE02: https://tricorder.pi-hole.net/k1A9ftyX/
Example of the issue from PiHole01:
[✓] ** FINISHED DEBUGGING! **
    * Error message: curl: (6) Could not resolve host: tricorder.pi-hole.net
   * A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
pi@PIHOLE01:~ $ nslookup tricorder.pi-hole.net
Server:         127.0.0.1
Address:        127.0.0.1#53
Non-authoritative answer:
tricorder.pi-hole.net   canonical name = docker-2-ny1.pi-hole.net.
Address: 164.90.255.4
pi@PIHOLE01:~ $
At the same time this happened on PiHole02:
pi@PIHOLE02:~ $ nslookup tricorder.pi-hole.net
pi@PIHOLE02:~ $
I did a PCAP from my router/firewall and see this for the traffic from PIHOLE01:
Your debug logs log inconspicuous, though they suggest you run a pretty elaborate DHCP setup for a multitude of network interfaces.
There is one peculiarity related to those interfaces, though:
The main interface eth0 is unconfigured:
    169.254.189.17/16
    169.254.58.201/16
It only carries a link-local IPv4 address.
What's the motivation for that?
LLAs should only appear on interfaces that haven't been able to acquire a proper IP address by DHCP nor through any other means like static configurations.
I'm unsure whether that would actually affect your DNS resolution.
But if that's not by your design, you should probably address that.
There are also slight differences between your configurations, e.g. only one of your Pi-hole's has a 05-pihole-custom-cname.conf.
I can't tell whether that's by intention, and whether that would have an impact on your observation.
And likely unrelated to your observation, but still:
As you are using .local as part of your local domain names, note that *.local FQDNs are reserved for usage by the mDNS protocol - they should NOT be used with plain DNS.
