PiHole should not crash.
I am using my network or computer and sometimes, seemingly randomly, PiHole is crashing. Where I'm unable to resolve DNS, I'm unable to SSH in or pull up the Web UI. The only thing that fixes it is powering my PiHole down by unplugging it and then plugging it back in.
I've been having this problem for a while, and replaced the SD card with a newer larger one (32GB i think).
There's no sign of crashes in the FTL log. If SSH is not working then there's an issue with either the OS itself or more likely the static IP address you have assigned to the Pi-hole.
When things are offline are you able to even ping 192.168.1.20 from a client?
Ping failure means either the entire OS is down or the network is not functional. Even if FTL crashed, and I'm not saying it doesn't but it's rare, you'd still have the network functional for ping replies.
The next steps would be to try and ping the IP from the Asus router when it's offline. Check the yellow and green lights on the network port of the Pi to see if they are lit or if they are dark.
I don't know how to ping it from the ASUS router. Do I need to TelNet into the router? I haven't done anything like that before but if you point me in the right direction for a google search I'll definitely try to learn it. I don't recall which lights are which, but the lights I saw were green and lit.
I don't know what KVM is. Isn't that a switch for monitors/workstations?
To connect via telnet using a Linux client (and maybe MacOS too):
nc <ROUTER_IP> 23
For Windows:
telnet <ROUTER_IP>
Keyboard Video Mouse though you probably dont need the mouse ... and need to get out the chair
Login and check basic things like ping or check IP address and if the interface state is UP:
[deHakkelaar] It happened again after a power outtage. The power came back on, along with my modem, router, everything. PiHole isn't reachable. I have to powercycle it for it to start up again.
I don't know what you're talking about getting out of the chair - what silly and totally unproductive comment.
I'm out of ideas. PiHole has become wildly unreliable for some reason. It doesn't respond to pings, I can't SSH in. The only solution is to powercycle. +
I know
But sometimes its the last resort if you dont have someone else to do it for you.
If those power outages occur frequently, that wont do the Pi no good.
Most computers dont like power outages when they are writing to disk.
The filesystem on the SD card might be corrupted already to the point where your experiencing those random crashes now.
Yes, static IP is set in my ASUS router, and I see it is connected under the proper IP that is static.
Yes, power outtages are no bueno for filesystems. I'm going to run pihole -r to repair it. Meanwhile, here is a fresh debug code: https://tricorder.pi-hole.net/wzg2ur7axq
Aaaaand v5 is available. So...may as well update and cross my fingers that fixes whatever ghost is in my machine
