I'm using an ethernet connection following tutorial from LTT. I cannot set a DNS server from the router so I manually set some of my devices's DNS to pihole. However, I noticed that pihole only recived a few traffics from each device instead of all the traffic. Also even if I disconnect the pihole, my devices can still access the internet. Which lead me to belive that somehow they are talking to some other DNS server. But right now I have no idea exactly what's happening how to fix it.
You have Pi-hole incorrectly configured for the active IP. Run pihole -r and select reconfigure, then select the correct interface and IP.
10.0.0.110/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=10.0.0.100/24
Thanks for the quick response!
I changed the ip address tp 10.0.0.110. However, I noticed that in the debug log it says the gateway did not respond. I checked and it's the right address for the gateway. Could this be the issue?
new log: https://tricorder.pi-hole.net/ikntxc8zls
